#151 |
Re: Sony FDR-AX100
nice piece Dave
#152 |
Re: Sony FDR-AX100
I may beg to differ as the Zeiss lenses on these cameras may have terrible cases of barrel distortion, but the processor is doing it's best to correct it. I do notice on the edges of the picture in the sample video some smearing possibly due to barrel distortion correction. Wonder why the price is so low? It's because they put a crap lens in front of a high-performance sensor and processor combo. It's a more extreme case than the C.A.C. in the EX1.
#153 |
Re: Sony FDR-AX100
I think I paid 2000 for a HC1 in late 2005. Using an inflation calculator I googled that's a little over 2300.00 today. Sony may well be utilizing the economy of scale algorithm (lol) and plan on selling these in the kazillions so manufacturing costs although high at the outset will dwindle whilst sales skyrocket. (certainly does not seem to be a cheapo lens...that's for sure)
So what about the pan handle zoom controller? Is it old school lanc, cx series which uses the a/v port or HX series utilizing the micro usb port which btw I have found to be problematic in that mains a/c and pan handle functions which use the same port cannot function concurrently |
#154 | |
Space Hipster
Re: Sony FDR-AX100
And I don't see much distortion, although I don't have a 4K monitor to view the footage. The footage looks outstanding to me. Sony probably could have put a better lens on it, but not for $2,000. |
#155 |
Re: Sony FDR-AX100
The VG series actually aren't marketed in the same "consumer" class either, meaning the AX100 is the new "flagship" consumer (they actually refer to it as "prosumer" on the web page) camera.
It's still a $2K camcorder, expensive, but not unheard of in "consumer" cams - the CX900 of course "fills in" the second highest slot at a more "consumer-y" price closer to the retiring 7xx series top of the line 1/2.88" sensor cams. The next 4K price point is what, $4500, and I'm not sold on the performance from a small sensor, vs. what the AX100 brings to the table. We have to have hands on to know how good or bad the camera will be in practical use, but it sure looks like the bang/$ ratio is in line. 4K, even if only 30p, plus what should otherwise be a pretty good 1080 60p camcorder with full manual and a nice combo of lens/sensor/processor... seems pretty reasonable to me even if there are a few quibbles here or there. It's definitely going to give the "competition" some fits (oh wait... what competition... when's that GH going to actually see market again?). Sony didn't put their foot in the door, they've kicked it down... |
#156 |
Re: Sony FDR-AX100
I agree, assuming that video really was shot with an AX100, it's WAY better than any $2000 camcorder that I know of today. The lens looks fine to me.
The fact that Sony didn't pull the typical "Handycam & NX30" trick of allowing you to control gain or shutter speed but NOT both at the same time....shocks me! It seems they didn't block anything. Anybody know a better $2,000 camera today? (GH4 might be a challange soon though) CT |
#157 | |
Re: Sony FDR-AX100
What would be great is if Sony entered the MFT market with XAVC MFT cameras competing directly against the AF100, but I think we all know they're loyal to E-mount, which leans more towards a APS-C sensor rather than MFT. |
#158 |
Space Hipster
Re: Sony FDR-AX100
That's the peculiar part: Sony seems to have put the better, bigger sensor in their consumer 4K cam, compared to their prosumer 4K cams. I definitely prefer a 1" sensor over a 1/2" sensor. I'll gladly sacrifice zoom range to accommodate the bigger sensor.
#159 | |
Re: Sony FDR-AX100
Ron Evans |
#160 |
Re: Sony FDR-AX100
@ Jack -
Sony ALREADY supports A and E series mounts/lenses in APS-c and now FF, why on earth would you think they would EVER jump on MFT?! They have a potent new combo with the RX/AX sensor and Bionz X processor, they aren't going to go reinvent the wheel and add yet another format in a shrinking market... @ Glenn - Sony is trying to (successfully by all appearances) open up some new markets for people who don't want to carry a bag of lenses and accessories, but still want better quality images and convenient to carry cameras. In the process, just as when they released the old TRV900 and HC1, they are creating some tools that border on "professional grade", and might even outperform on some levels, and meet the needs many pros might have for "personal" cameras that don't deliver lousy results! I'd also expect that perhaps there will be some pro cameras with this sensor/processor once they vett it - the sensor and processor look to have a lot of potential. |
#161 | ||||
Re: Sony FDR-AX100
Let's assume a sensor of dimensions 4608x2592 in 16:9 video mode - simple maths shows it's virtually 12 million photosites, so consider it typical for a sensor for a primary still camera. If you were to read to get 1920x1080 values directly, then how would you do the grouping? Divide 4608 by 1920 and you get 2.4 horizontally, same number vertically. But you need to be thinking of whole numbers - "binning" implies reading the charge from a photosite and putting it in a "bin" along with charges from it's neighbours. Hence each photosite can only contribute towards a single value. And in the past it's been essential to simplify, to speed up the readout, to achieve frame rates. Thinking of Bayer geometry, the basic pattern is a 2x2 block - 1 each of red, blue photosites, and 2 green. In practice, it's been necessary to think about doing the grouping in terms of 4 such blocks - so a 4x4 grouping of 16 photosites (so 4 R, 4 B, 8 G) So each of these becomes a "basic resolution element". And it therefore follows that the resolution will be the sensor dimensions divided by the block dimensions, so division by 4 in such a case, which here would predict 1152x648 - something slightly less than 720p standard. For output, it would be scaled up to 720 or 1080 format for recording, though obviously the actual resolution could never be better than 648lpph in that particular case. And measure the results from such "primarily stills" camera sensors, and that's exactly what they do show - in ball park figures anyway, the exact figures will vary depending on the exact dimensions. And that's why such as DSLRs have tended to give "roughly 720p performance", even in 1080p rec mode. But well, 720p isn't bad is it? And to get it from a still camera sensor......? But times move on. Quote:
But as with so many things, the more effort that gets put in, the more you can get out. In the example above, the 4x4 binning approach gives you about 648lpph. Do a full deBayer, and you could expect luminance resolution of around 75-80% of the sensor dimensions - so around 2000lpph. In other words, something like true 4K. It's worth mentioning again that you can get the best of both worlds (simple and easy processing, with good performance) if you use 2x2 blocks, and make the sensor dimensions twice the desired resolution - 3840x2160, if you want 1080p. That should give full HD resolution via simple processing - and is exactly what cameras such as the Canon C300 do. But such a sensor is 8 megapixel and not nowadays regarded as good enough for still photography. Now, has my computer finished rendering? Back to work! :-) |
#162 | |
Re: Sony FDR-AX100
It's way more likely we'll see an E-mount (as I've repeated many times in this thread) EA50 successor. NAB could bring the 4K back to the prosumer en masse. |
#163 | |
Re: Sony FDR-AX100
Ron Evans |
#164 | |
Re: Sony FDR-AX100
#165 |
Re: Sony FDR-AX100
"$2000 camera" and "consumer" don't make much sense to this fella. I guess the true definition of consumer is whether or not you can buy it in a best buy or pc richard or whatnot
What consumer items that are considered luxuries, not necessities, bridge the $2000 mark? homes, cars, some high end washer/dryers, all are i would gander the majority of the time: necessities TVs would be the obvious comparison, but most are way below the $2000 mark. and if people are spending say an average of $1000 on their TV, why would they spend twice as much on a camera, something that is used far far less than a daily use TV... I think they should have embraced the prosumer nomenclature, or ditched even more features and make it closer to the $1000 mark. this is the first THREE ND filter consumer camera... |
