#1516 | |
Re: Sony FDR-AX100
more frames per second are mostly for slow motion. Don't get smart on me now. Let's try to explain the building curved on pans. regardless of the number of the frames involved. |
#1517 |
Re: Sony FDR-AX100
Curved objects = rolling shutter.
EX1 sensor = fewer pixels + designed for video = faster read out = less rolling shutter. AX100 sensor, designed for photos + more pixels = slower read out = more rolling shutter. EX1 $8K AX100 $2K You get what you pay for.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
#1518 |
Re: Sony FDR-AX100
My AX100 review is here:
#1519 |
Re: Sony FDR-AX100
Sony, can you PLEASE add a firmware update that allows us to assign the top handle button (the "photo" button) for focus expansion?
The button you have today for that is in the absolute WORST place on the camera. It's absolutely impossible to reach with your finger. And, I'm absolutely certain that no Sony engineer, designer and camera tester can reach it with their fingers either. I'm quite surprised that an important function like this was allowed to exist in such and knowingly inaccessible place. You did this for the NX70, please for it for the AX100. It's a bit of a embarrassing joke right now that Sony can easily fix today. I was hoping Alister would mention this out loud in his review. (They might actually listen to him if he shined the light on it...and I'm sure he must agree with me on this.) CT |
#1520 |
Re: Sony FDR-AX100
I would be surprised if Sony would make a change true a firmware update, on the nex-ea50 there where many features asked by users to improve upon or to add of which the possibility to change the iso with the dial on the side (like you can with the shutter) instead of having 3 fixed selectable iso values with a switch which was my top one on the list. Sony did release one firmwareupdate but that included options nobody asked for.
Improvements are usually made with new models, like when people ask for the possibility to have 4K on the rx10 which I understand the sensor is capable off yet I"m sure that won't happen, unless they bring out a rx10 4K model. As much as Alister is a respected filmmaker, I don't think Sony would listen to his reviews and make changes based on his findings, at least not on existing products, by the time Alister has a review ready Sony already has another camera in the pipeline with all focus on that one :) |
#1521 |
Re: Sony FDR-AX100
Your 'curved' building problem is called rolling shutter. When a sensor reads the lines of pixels from top to bottom instead of all at once. That's what causes your curved buildings and by far the main factors of its severity are resolution and read speed.
#1522 |
Re: Sony FDR-AX100
BTW Alister, great job on your three AX100 videos. (Focus, overview and exposure)
I would love to see you do a "technical evaluation" too. Maybe dynamic range and resolution chart tests? (Sony AX100 vs Sony AX1 or Z100?) What is your opinion on the 60mbps codec limit? I have noticed with a bitrate analyser that the codec will actually do up to 72Mbp/s spikes at certain times. I find myself always expecting much worse results than I actually get with this codec. It's surprisingly "OK" (but I still have a hard time accepting it) I have noticed however, that this codec breaks quickly when trying to grade something. If you shoot perfectly in the field than you will be OK but making any significant adjustments in post makes compression artifacts "pop" out quickly. What do you think Alister? CT |
#1523 |
Re: Sony FDR-AX100
Cliff, your assessment of the codec is pretty good. As you say it works very well considering it's only 60Mbps. There are a lot of artefacts in the recorded image but these don't tend to be too noticeable unless you grade the image. I don't think I would like to pass the 4K though a broadcast chain, although it does hold up really well when going to YouTube etc. What really surprises me is that even very rapid major changes to a frame are handled very well, for example fast pans or lightning bolts won't break the codec. It does soften (as expected) but does not break down as many other H264 based codecs can.
I would eyeball the dynamic range at about 10 stops. Onset of over exposure is a little sudden, I'd like to see a bit more roll-off, but for a camera in this price bracket it's pretty good. I don't have any 4K resolution charts, I really need to get some and my Imatest licence has expired. It's very obviously significantly higher resolution than HD. I do need to do some tests on the image sharpness. It is very sharp and I would like to ascertain how much of that is just pure resolution and over-sampling and how much is in camera sharpening. I also want to look at what happens when you add a touch of diffusion to take the edge off the image. It's just this stuff takes time to do right and I've been really busy lately. For me this camera is very much like the HC1 that came out in the early days of HD. The HC1 (and A1) was never quite as good as the Z1 etc, but for the money it produced a very useful image and the AX100 is similar. I prefer the AX100 over the Z100, but it's not an F5 or FS700 with raw recorder.
#1524 |
Re: Sony FDR-AX100
MODERATOR NOTE:
As those posting to this thread over the past couple of days will notice, it has been heavily pruned to remove the worst of the rudeness and flaming. Be nice.
Pete Bauer The most beautiful thing we can experience is the mysterious. It is the source of all true art and science. Albert Einstein Trying to solve a DV mystery? You may find the answer behind the SEARCH function ... or be able to join a discussion already in progress! |
#1525 | |
Re: Sony FDR-AX100
too slow? So how about the framerate now? nuthing to do with THAT, correct? And now the fact that with the stabilization off it gets better may be due to the other fact that the stabilization takes processing power away from the readout. It all makes sense now. So it wasn't the 30p thingy. Well put Darren! |
#1526 | |
Re: Sony FDR-AX100
#1527 |
Re: Sony FDR-AX100
Judder and rolling shutter are two different things and neither has anything to do with processing.
Judder is related to frame rate, resolution and shutter speed. Bending verticals is rolling shutter caused by the slow scan rate of the sensor. More pixels take longer to read so unless you have a very fast sensor the readout rate slows down. This is very typical of sensors designed for stills rather than video. Faster shutter speeds will make rolling shutter more obvious as there is less motion blur to disguise the artifact. The videos are only on my YouTube channel at the moment. A written review will go online some time next week along with links to those videos. More in depth tests will follow when I have time between shoots.
#1528 | |
Re: Sony FDR-AX100
This sort of "test" is exactly the sort that drives one nuts - OF COURSE, when you FULL ZOOM with CIZ on, it's a digital doubler, but if you compared 12x and 12x and took note of the line in the zoom indicator, the two will be comparable... maybe it's the "Queens' English" vs. US English, but I'd give that "test" a big thumbs down as the narration is misleading and inaccurate... indicating to me the "tester" does not know how these things work.... Most likely the CX900 and AX100 1080 modes will be identical... but of course at 4K, detail is an entirely different ballgame. Yes, a small crop is required for "active" stabilization. Pretty much like saying you need eggs to make an omelet... and if you use egg whites it'll be a different color... |
#1529 |
Re: Sony FDR-AX100
#1530 | |
Re: Sony FDR-AX100
