SI-2K and wide angle lenses
I've read of a potential problem with certain types of sensors and certain wide angle lenses that have a small exit lens. Fall off occurs because unlike film, CCD sensors are affected by the angle at which the light strikes them. Obviously this might be a problem affecting any sensor and might explain what I've noticed with some footage shot with WA stills lenses.
Is this issue likely with a CMOS sensor, if so any lenses we should avoid. |
Hi Bob,
It's not quite a concern because of the back-focal distance being quite large in the case of PL-mount, and the sensor itself being only 2/3" rather than having to cover a 36x24mm rectangle like still-35mm-photography. With C-mount lenses though, it could be an issue with really wide-angle stuff. We have used 9.5mm lenses with no problems, so I'm sure you can go wider than that before any visual fall-off problems result . . . again, in the case of PL-mount, I'm not concerned, but the c-mounts might pose an issue at super-wide angles because the back-focal distance is so small. |
Thanks Jason,
one less issue to worry about as we're only going with PL mount lenses at this stage. |
Heh, I asked the same question but about fast lenses like my f0.95 a while ago.
Now I have an even faster f0.85 c-mount with 1" sensor coverage, I really hope someone in atlanta get's an SI-2k so I can test it out :) |
#5 |
Wow, where did you get a c-mount with that wide an aperture? We've never tested a lens that wide . . . so not sure if there will be port-hole type effects with an aperture that wide. I do know though that you're typical >f1.2 apertures should have no problems.
#6 | |
Got it on ebay, paid a good bit. It's discontinued, but some places still stock it for around $400-$600 |
