Accessories for the SI-2K mini at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old November 3rd, 2006, 07:59 PM   #1
Intending to order a SI-2K mini, I include a "first choice" list of accessories hoping to receive comments or suggestions on better options. Thanks
Hardware: G5 (owned) and Mac Book Pro 2.33 GHz 2 GB RAM
Software: FCS (owned)
Raid: Western Digital My Book Pro edition II (1TB, Firewire 800)
7" touch screen: Xenarc 700TSV
Battery & charger belts (for Mini and 7" touch screen): Bescor 12V 144Wh - 12AH and 288Wh - 24AH
Stabilizer: Varizoom Flowpod Stabilizer System with low mode and case
Digital audio recorder: Edirol/Roland R4
Rods, matte box and flag: Cavision RSSA-1525 and Cavision MCF-16 clamp
C mount industrial prime lenses:
Schneider - Cinegon 4.8mm, Cinegon 8mm, 150mm
Switar - 10mm, 50mm
Fujinon - HF12.5SA-1, HF16SA-1, HF25SA-1
Two questions:
1. What battery connector requires the Mini (4 pin XLR?)
2. Is Prospect 2K needed with FCS?
Melvin Torrens is offline   Reply With Quote
Old November 4th, 2006, 12:27 AM   #2
Silicon Imaging
Two questions:
The MINI has a 12-Pin Hirosi. We'll put any connector you want on the other end of the power cable.
You need P-2K to use AE and 32-bit floating point color correction. There will be an upgrade path for QT support.
Ari Presler is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
