Shooting B&W with the Silicon? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old June 9th, 2006, 11:41 PM   #1
Is any optimisation possible to record the best possible monochrome image?
I'll freely admit I don't fully grasp the implications of all I've read about B&W Vs color imaging other than that ideally there's more to it than just loosing the chroma information.
Despite my lack of understanding I thought given the resurgence of B&W it's a question worth throwing into the mix.
Old June 10th, 2006, 01:08 AM   #2
Silicon Imaging
Shoot B&W Silicon!
Yes. We are offering Silicon in B&W(Mono).
There are several siginificant benefits for using the Silicon B&W over shooting any of the Y:U:V formats including:
Higher spatial resolution (1000TVL+)
Higher sensitivity
Higher quality coding
We expect to see some productions done in mono, including 3D Anaglyphs.
Ari Presler is offline   Reply With Quote
Old June 10th, 2006, 05:01 AM   #3
Cool what is the Higher spatial resolution in Y:U:V format?
Yasser Kassana is offline   Reply With Quote
Old June 10th, 2006, 07:46 AM   #4
Silicon Imaging
B&W Resolution
The reference to Y:U:V had mostly to do with the coding formats comapred to HDCAM or DVCPRO-HD (I didnt mention the 4x luma accuracy of our 10bit format vs 8-bit). If you compare to SR the differences are more subtle.
In Monochrome, every pixel can be either black or white, or a unique line. If you look at square resolution, there are 1080 lines.
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
