SI-2K CMOS Size at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old September 17th, 2009, 08:38 PM   #1
SI-2K CMOS Size
I post in the silicon imaging forums last week and no one answer me.
I read in a Fletcher comparison chart that the SI-2K sensor is 10.3 X 5.76 mm. Is this accurate?, s16mm is 10.6 X 6 mm, so the difference would be really small 0.033%.
ANDRONICO GONZALEZ
Director of Photography - Mexico
Andronico Gonzalez is offline   Reply With Quote
Old September 18th, 2009, 01:16 AM   #2
Hi
the sensor has pixels size of 5 microns.
So full 2K is (2048x1152)=10.24x5.76mm
1080 (1920x1080)=9.6x5.4mm
720 (1280x720)=6.4x3.6mm
Hope this helps, have not had time lately to check SI forum.
-Kaspar
Kaspar Kallas is offline   Reply With Quote
Old September 18th, 2009, 03:39 AM   #3
I was under the impression that Super 16 frame size was 12.52mm x 7.41mm (std 16 10.26 x 7.49)
There does seem to be a different field of view from S16 to SI-2K
Rohan Dadswell is offline   Reply With Quote
Old September 18th, 2009, 08:23 AM   #4
Hi
You are correct about S16 (16 mm film - Wikipedia, the free encyclopedia)
I use multiplier of 1.2(2)
-Kaspar
Old September 19th, 2009, 12:17 PM   #5
Hi Kaspar & Rohan,
By a mistake in my notes I use the frame size of standard 16mm instead of s16 mm, but you are also wrong because Wikipedia dimensions doesn't use the standard ISO 5768:1998
As you can see Panavision or Zeiss does:
Information: Formats
http://www.zeiss.com/C12567A8003B8B6F/EmbedTitelIntern/ARRIUltra16Brochure/$File/ARRI_Ultra16_brochure.pdf
Kaspar, Where do you find the info about the pixel size in SI-2K CMOS sensor?
ANDRONICO GONZALEZ
Old October 1st, 2009, 03:47 PM   #6
Silicon Imaging, Inc.
Kaspar is exactly correct in the sensor pixel size and the effective sensor size at various resolutions. It should be in our specs and is in the FAQ. One of the problems in saying that a sensor is exactly a film size is the variation in aspect ratio involved.
-Steve
We see the Light!
http://www.siliconimaging.com
Steve Nordhauser is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
