SI-2K Mini Handheld at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old September 2nd, 2009, 04:14 PM   #1
SI-2K Mini Handheld
What do you use to stabilize the Mini while handheld, and to do Follow Focus?
I just stumbled upon this contraption, originally made for Canon 5D Mark II:
Cavision | Follow Focus Shoulder Mount Package | RS5DM2SET-F
Will this work with the Mini?
Alex Raskin is offline   Reply With Quote
Old September 2nd, 2009, 09:58 PM   #2
I use the original accesories of PS Technik, but are expensive.
Also Zacuto has a package of accesories designed for the SI-2K
Zacuto USA 888-294-3456 | Zacuto - SI-2K Kits
The Cavision contraption will work if you take off the LCD cover, put the 7" touchscreen monitor, and put a battery holder with the correct Lemo adapter and a Bauer-tap to connect the Touchscreen.
ANDRONICO GONZALEZ
Director of Photography - Mexico
Andronico Gonzalez is offline   Reply With Quote
Old September 3rd, 2009, 09:47 AM   #3
frame discreet si2k
I'm using a DV Multi-RIG pro. It's a cost effective, quite versatile solution. Lots of threads and spots to hook on additional accessories.
For lighter weight, I use a simple photography bracket which I can mount a shotgun mic instead of a flash.
Pictures of some of the rig setups in my blog.
FrameDiscreet.com transfers // cinematography
all the best!
Justin Lovell is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
