.looks lost in post-production? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old August 9th, 2009, 07:54 AM   #1
After transferring RAW video files to a different machine (with Cineform Prospect HD installed), editing is fine but the .look presets from SI-2K are lost.
Is there a way to uphold them in post on a different machine than the one used for the acquisition?
I capture footage with a laptop, but edit on the desktop.
Thanks.
Alex Raskin is offline   Reply With Quote
Old August 9th, 2009, 03:24 PM   #2
When you transfer your footage make sure you transfer the .look files as well.
On the new machine double click on each of the .look files, these are then installed on this machine.
Rohan Dadswell is offline   Reply With Quote
Old August 9th, 2009, 03:29 PM   #3
Thanks Rohan.
I did that originally, but no cigar.
Apparently Prospect HD does not support RAW metadata, including .look settings. (but it does support playback of the rAW video itself.)
So now I'm looking into upgrading to Prospect 4K...
What are you using as codec/NLE/compositing soft?
Old August 9th, 2009, 08:04 PM   #4
Solved! See here:
http://www.dvinfo.net/conf/cineform-...ml#post1202590
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
