Windows xp pro for si2k mini at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old March 5th, 2009, 12:37 AM   #1
For using a laptop or desktop for a recorder unit for the SI2K MINI, does anyone have a list or recipe of what needs to be stripped from Windows XP for best performance.
It is proposed to shoot 2048 x 1152 in adaptive mode.
Any advice will be greatly appreciated.
Old March 5th, 2009, 02:16 PM   #2
Hi
Actually you dont have to strip down anything for best performance, the only thing influenced is the boot up time.
-Kaspar
Kaspar Kallas is offline   Reply With Quote
Old March 6th, 2009, 01:15 AM   #3
Having the right network card correctly setup is about all I've found to matter.
To state the obvious sending emails while recording is not advised.
Disabling any drive indexing would be recommended, in fact any service that runs periodically or even ones not required are best turned off. All this can be achieved with them still installed. Outside of Windows itself there's probably a long list of applications that one shouldn't install as they install services that can be fiendishly difficult to prevent from running.
Old March 6th, 2009, 07:57 AM   #4
Silicon Imaging
Most importantly turn off any IM messenger services.
Ari Presler is offline   Reply With Quote
Old March 8th, 2009, 12:18 PM   #5
Thanking you folks for your respective advice.
I had delusions of being able to use the computer I now have rigged for editing as a recorder unit, however it has gone down in a screaming heap and is proving very difficult to resurrect.
Bob Hart is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
