3D Configuration for SI2K - Page 2 at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old July 16th, 2008, 11:16 AM   #16
Sponsor: ZGC
3D Rig for SI-2K
Greetings,
P+S Technik does have a 3D solution for the SI-2K camera.
http://www.pstechnik.de/en/3d-rig.php
I hope this helps,
Diana L. Janos
ZGC Inc.
Diana Janos is offline   Reply With Quote
Old December 30th, 2008, 07:03 AM   #17
Originally Posted by Jason Rodriguez View Post
You also might want to try Nuke instead of AE, as it has native 3D editing and display capabilities now with version 5.0.
Nuke support CineformRAW ?
Serge Victorovich is offline   Reply With Quote
Old January 1st, 2009, 03:27 AM   #18
Currently at the moment there are some compatibility issues that have been reported by customers using Nuke and CineForm RAW, although I'm not exactly sure what the issues are, other than some customers basically reporting "it doesn't work", and then not elaborating further.
Since I don't have a copy of Nuke, I'm not able to elaborate further either, although I do know that CineForm RAW works nicely inside of Shake.
Jason
Jason Rodriguez is offline   Reply With Quote
Old January 5th, 2009, 03:32 PM   #19
Hi
Nuke 5.1 works but it will have memory issues if too many inputs are used (20 read nodes using CF qt 2K)
prior to 5.1 does not work!
-Kaspar
Kaspar Kallas is offline   Reply With Quote
Old January 6th, 2009, 06:46 AM   #20
Jason and Kaspar, thank you for info!
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
