SI-2K on a Jib at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old November 29th, 2007, 08:45 AM   #1
SI-2K on a Jib
How do you record with the DVR on a Jib w/ remote head?
Bhaskar Dhungana is offline   Reply With Quote
Old November 29th, 2007, 04:42 PM   #2
I haven't got the full DVR yet so still using the mini with a laptop but have run the mini on a Jimmy Jib - I imagine that I'd use a similar set up even when the full rig arrives.
SI Mini on the remote head, power & gigabit cable down the jib arm to laptop/battery. Monitor for jib operator - can be touchscreen for rolling by jib op or director can roll from laptop.
One advantage of this set up is a lot less weight is needed on the jib but if you were to put the full DVR rig on the remote head you could run a VGA & USB cable to the jib operator so they could see and control the camera.
Rohan Dadswell is offline   Reply With Quote
Old November 30th, 2007, 01:56 PM   #3
Very simple
You simply stick the LCD running the DVR on a C stand
just the mini on the crane head
Lior Molcho is offline   Reply
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
