University Innovation Center at DVinfo.net
Show Your Work
Let's see what you're doing!
Old October 31st, 2017, 12:08 PM   #1
Put this quick little video together to highlight the Innovation Center that opened on our campus last January. Let me know what you think. Constructive criticism is encouraged.
Brock Burwell is offline   Reply With Quote
Old October 31st, 2017, 03:02 PM   #2
Re: University Innovation Center
Brock, I think this shows some terrific improvement over some of your past videos. Great job.
You should play with your shutter functionality to try to eliminate the scanlines when you're filming screens. It wasn't all of them, but the drawing screen was especially bad. I would try normal shutter speeds first, and if you can't get rid of it that way, then go into Syncro Scan on your GH4. It definitely takes some time to hit on the right combo, but it's worth it in my opinion.
I had an issue with just LED lighting that was 60.59Hz and it was definitely flickering. The problem was, I didn't notice it on the GH5's small screen. Thankfully, on the second camera with the 702 SmallHD, I noticed it, and at the break tweaked the shutter to match that, and then used Syncro Scan on the GH5 to eliminate it there as well. For the first segment, I'll just use Digital Anarchy's Flicker Free plugin to fix it, though that is primarily for time-lapse, slow-motion, and LED lighting, so not sure if it works with monitor flicker, but you can check it out for future uses.
Old October 31st, 2017, 03:07 PM   #3
Yes, looks really great Brock! I can see you implemented some of the things you were posting about last week. Spot on. Very exciting, that's a LOT of shots! Really like the hyperlapses and fast moving drone shots.
For the flicker on the board, you might try this trick: duplicate the clip, set the opacity to 50% and then paste it over the original with a 1-frame offset. It blurs the video a bit but may help the flicker.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old November 1st, 2017, 08:55 AM   #4
I'm not going to lie, I didn't even realize there was a way to fix the TV flicker. I'll definitely be on the lookout for that in the future. Thanks!
Old November 1st, 2017, 08:57 AM   #5
Wow, your little trick worked perfectly. Thanks!!
