Letus / XH A1 Fotage at DVinfo.net
Show Your Work
Let's see what you're doing!
Old October 18th, 2009, 09:51 PM   #1
Test with the Letus on the XH A1. Any feedback is welcome.
* I forgot to turn the Letus on so it's more grainy than normal.
Oliver Darden is offline   Reply With Quote
Old October 18th, 2009, 11:50 PM   #2
The point of the letus 35mm adapter is to let you use photography lenses. This lets you create a more shallow depth of field than the camera could normally achieve.
For the most part, everything looks in focus all the time. Couldnt you have done this same exact thing with just the xha1 and without the letus?
Anthony Castaldi is offline   Reply With Quote
Old October 19th, 2009, 09:14 AM   #3
If the letus wasn't on this footage wouldn't look like this at all. It would look much more "in focus" and digital. I was also bord with all the letus footage like that that I saw on vimeo. Seems like everyone that has one does those same DOF shots so I tried using door frames etc to show depth. Trying to not be so obvious you know?
Anyway, thanks for the feedback as I am still learning how to use it fully.
Old October 24th, 2009, 01:23 PM   #4
no password for the password protected video.....?
Doug Marcum is offline   Reply
