Multirig Pro or DvRigPro for Canon A1 - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old May 31st, 2007, 04:58 PM   #16
It is front heavy...but the weight is taken by the support rod and belt (as you can see in the pics). It's evenly balanced through the rod so there's minimal strain on my arms (I can balance it with a finger under each handle). I shot for 45 mins comfortably - but I imagine my back would complain eventually.
I'm curious whether there are other rigs out there that are more suited to the job. But even if that were the case I doubt they'd match the flexibility of the MR...and certainly not at that price.
Steve Madsen is offline   Reply With Quote
Old June 1st, 2007, 04:00 PM   #17
DV Rig Pro
>>> For better balance, move the whole setup back and use an external LCD
on the left grip joint.
Yes, The new DvRigPro HD is designed for both standard camera setup on the front bar or a 35mm setup on the side bar over the shoulder.
www.dvtec.tv
Danny Natovich is offline   Reply With Quote
Old June 1st, 2007, 04:56 PM   #18
Thanks Danny...good info.
Old September 17th, 2007, 08:00 AM   #19
Which handheld configuration did you go with?
Bruce, I'm considering the Multirig pro for a Brevis mounted HVX setup. Total weight 9lb and centre balanced (on rails). The DVRig HD Pro is designed for this setup, but the versatility of the Multirig has me interested. Do you think the the Multirig could handle such an application? How about the stabiliser plus config (out in front)? If you feel your opinion unqualified I'm still interested to hear you thoughts. Thanks.
Steve,
I'm very curious as to where you ended up. I have the exact same situation (except with a Canon A1). I have invested in a Brevis system and a Merlin, but am curious as to which way is the best to go in the event of needing to go handheld. Did you get an answer & go in any particular direction?
Best regards,
--Brandon
p-films.com. Canon T2i f2.8 17-55, f1.4 50mm, Cool Lights LEDs
Brandon Paschal is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
