Home-made project - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old July 31st, 2006, 11:18 AM   #16
It are brackets for copper 15 mm water tubes, from the local Do-it-yourself shop...
Julian Jansen is offline   Reply With Quote
Old July 31st, 2006, 03:05 PM   #17
Brilliant!
PAL shooter in NTSC territory
Patrick Jenkins is offline   Reply With Quote
Old July 31st, 2006, 03:08 PM   #18
Any updates , that will come this week (deadline is sunday ), I will post here with pictures.
Hope other people that try to build one or have build one will share there experiance here.
Old August 4th, 2006, 01:09 AM   #19
The shoulder part:
Before the finishing touch:
http://img124.imageshack.us/img124/7...rbeforeqz0.jpg
After:
http://img137.imageshack.us/img137/4...erafterzh6.jpg
http://img140.imageshack.us/img140/6...ownsidejd1.jpg
Old August 4th, 2006, 01:10 AM   #20
The 15mm tube:
http://img138.imageshack.us/img138/816/tubezd6.jpg
Old August 4th, 2006, 08:39 AM   #21
Looks good! Not sure if you had this covered already, but through some some/rubber on the curved side of the shoulder support (ie: I've used that round foam home pipe insulation material). Even though it's a bit ergonomic already, a flat surface will definitely ache after a short while. Also, the rubber will allow some shock absorption if you move.
Old August 4th, 2006, 09:04 AM   #22
making cool camera mounts with wood...you're my kind of DIY guy!
Web Youtube Facebook
Cole McDonald is offline   Reply With Quote
Old August 4th, 2006, 03:40 PM   #23
Already have the rubber laying around ;)
Old August 4th, 2006, 03:46 PM   #24
Total spent sofar:
Wood: Free
Iron tubes: Had them already laying around
Brackets: 13.17 euro
Old August 4th, 2006, 03:51 PM   #25
More pics:
http://img313.imageshack.us/img313/373/001wz8.jpg
http://img411.imageshack.us/img411/5734/002pv0.jpg
More pics tomorrow , I need some sleep...
Old August 4th, 2006, 04:41 PM   #26
I don't know how well those clamps hold, but you may want to consider adding a layer of leather or rubber (sounds like a good club name) in those brackets to stop them from biting into the tubes...it'll add a little shock support as well.
Old August 4th, 2006, 05:17 PM   #27
The brackets are made from lead. They are pretty strong...
I made them smooth at the inside so it doesn't damage the tube...
I'am going to paste 1cm thick rubber under the shoulder support and under the camera. I think that will be enough.
Old August 9th, 2006, 08:42 AM   #28
Lookin good!
Old August 11th, 2006, 06:50 AM   #29
I finished the basic setup last week. So here are the promised pictures:
http://img153.imageshack.us/img153/3637/003jw4.jpg
http://img97.imageshack.us/img97/8772/004eo5.jpg
http://img97.imageshack.us/img97/4577/005ge5.jpg
http://img88.imageshack.us/img88/8453/006yl7.jpg
http://img88.imageshack.us/img88/5550/007gk3.jpg
http://img153.imageshack.us/img153/3231/001vx5.jpg
The only thing left to do is making a sun-shield, handels and finetune some things...
Old August 14th, 2006, 08:55 AM   #30
Anyone experience with the sizes of sunshields?
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
