toertlerig at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old February 21st, 2006, 04:05 AM   #1
toertlerig
Is anyone using this rig with a Z1 or similar?
http://www.easyrig.se/tortlerig.html
Any experiences would be welcome.
alex
Alex Horvath is offline   Reply With Quote
Old February 22nd, 2006, 01:45 AM   #2
I have ....
a marzpack which is the same thing. It works pretty well with my DVX fully loaded. The front end can be a bit on the heavy side so you have to get creative about how you balance the cam. I modified an inexpensive shoulder rig (added handles so it works like a steady cam) to use as the base plate for the cam and balanced it with brass weights at the bottom center of the base plate and on an off axis bar that counter weighs the 7" monitor I use. As long as you are doing hand held, it's no problem. It's not bad as a steady cam and does come in handy when in a crowd.
Dean Harrington is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
