Z1/FX1 shoulder rest - Page 2 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old February 28th, 2007, 11:59 AM   #16
Originally Posted by Jon East View Post
The spider brace works great. Use a quick release adapter for it so it will fit your tripod too. I use the bogen 501 head so I bought the quick release place that is the same as the 501 head.
Forgive me for reviving an old thread, but I'm researching the Spider Brace and am puzzled by the comment quoted above - their web site says the Spider Brace is not readily tripod-mountable. So is it or isn't it?
Old February 28th, 2007, 12:44 PM   #17
Kevin:
I think what is being said is you can buy plate that you mount on the Spider brace to make it a quick release compatible with your tripod. Here is the item. I just bought one to attach to my SteadyStick... You bolt it on to the existing threaded attachment used for the camera so you can switch between Bogan tripod and Spider brace quickly. It comes with an additional plate. Here is the item:
http://www.bhphotovideo.com/bnh/cont...shs=577+Quick+
Chris J. Barcellos
Old February 28th, 2007, 12:56 PM   #18
Thanks Chris. So I would attach the Bogen quick-release plate to the top of the Spider brace and mount my camera to the quick-release plate using a standard Bogen tripod mount? Sounds good.
Old March 1st, 2007, 12:30 PM   #19
Yes, that is correct. :)
Chris J. Barcellos
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
