dvmultirig pro support pod screw size? at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old December 3rd, 2009, 08:23 PM   #1
Danny - can you do me a favor? The thumbscrew on the spring support pod - can you let me know if possible the size of the hex head bolt that goes in there to which the black thumbscrew attaches?
I must have left my thumbscrew too loose after using it and the thumbscrew came off in transit. I have the thumbscrew but can't find the bolt.
I bought the closest match I could find (a metric size) but it may be a tad loose? It'll work for now but I figure I might as well replace it with the right size.
Anyway if you can tell me the screw size you use (upper thumbscrew bolt) that would be great. If not, it's no big deal really.
Thanks, and the multirig pro continues to be a great tool!!!
Dave Stern is offline   Reply With Quote
Old December 5th, 2009, 02:37 AM   #2
DV Rig Pro
Its M5 (5mm) Let me know if you are OK or I should mail you a replacement.
www.dvtec.tv
Danny Natovich is offline   Reply With Quote
Old December 8th, 2009, 01:17 PM   #3
hi Danny, I am all set, thanks! I picked up a few at Sears locally - was very easy. Good luck with your new products!
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
