Attention DvRigPro Owners. at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old May 2nd, 2005, 02:26 PM   #1
DV Rig Pro
If you like the "Compact Dual Handle No shoulder Brace" support.
Part of the DvRigPro advantages is using the dual handle wide grip system, You can easilly convert your DvRigPro by removing the side bar and the shoulder brace
and use the front bar + the handles and the support pod as a stand alone unit.
Just remove the front large knobe, Make sure not to lose the bearing and washers, remove the side bar and screw the large knob back.
Use it with or without the pod, you can also mount the handles on top for low angle shoots or add another pair of handles.
Try it, It's interesting and post your results.
Danny Natovich
DvTec
Danny Natovich www.dvtec.tv
Using a DvRig every day keeps the doctors away.
Danny Natovich is offline   Reply With Quote
Old June 6th, 2005, 02:34 PM   #2
Danny, do you have a picture you can post of this setup? Thx.
Shawn Murphy is offline   Reply With Quote
Old June 6th, 2005, 02:43 PM   #3
DV Rig Pro
I will add a new modification page and upload few DvRigPro modifications
next week.
Danny.
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
