#16 |
DV Rig Jr.
I got my DV Rig Jr at Kennedys ENG in Euless *(between Dallas and Fort Worth). And yes, the keyring thing doesn't work worth a crap. My solution, which has been rock-solid for almost a year now, was to super-glue the keychain ring into its recepticle. Then I just took a carabiner, looped it through the ends of the neck strap, and now I clip/unclip my carabiner to the firmly-glue-in keychain ring.
Works wonderfully~ PS On shooting with the rig itself, I've found it quite effective and very handy, but I'd still like a better solution for the sheath-thats-connected-to-tha-Hip-Bone. It's not very comfortable after a long day of shoot (depending on your total camera weight, and how much you support your arms, therefore adding more "weight" to the affair). I tried, once, using some additional padding between the sheath and my hip bone, but it didn't work so well. Maybe I could rig a basketball knee pad to it (I use those a lot on my should with the full-size cameras). Just have to come up with a solid rigging solution that (hopefully) doesn't include gaff tape. Hope that helps! Travis Petty Director Camera Frozen Fire Films 214-868-1651 www.frozenfirefilms.com |
#17 | |
DV Rig Pro
DVExpo in the Los Angeles convention center 5-6 December.2007 We will have special discounts at the show for details visit: www.dvtec.tv
www.dvtec.tv |
#18 |
I use a Lowepro harness and deluxe waistband. Is the loop on the DVRig Junior holster compatible with the 2" sewn loops on the Lowepro waistband (see attached)? The Lowepro attachments us a 2" stab that locks onto the belt with velcro.
Lowepro harness and belt: Lowepro - S&F Vest Harness Lowepro attachment system: http://products.lowepro.com//Catalog...029-IMG3L.jpeg |
#19 |
DV Rig Pro
The Junior Rig Holster has a spring clip that can be easily attached to
your belt. If you do not need the suplied belt print a note in the order form and you will get a $ 20 discount. Danny.
www.dvtec.tv |
#20 |
I can work with that. Another question I have is about the shock absorbing pod. Is the spring tensioned in any way and about how far is the travel in the absorbtion?
#21 |
DV Rig Pro
You have about 30 Cm of spring range, and another 30 Cm up without spring support. depending on camera weight and operators height.
www.dvtec.tv |
