Cavision Shoulder Mount - too far to the side at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old May 17th, 2008, 08:58 AM   #1
Guest
Posts: n/a
http://www.cavision.com/rods/RS1580S-SPE.jpg
Is it possible on this Cavision shoulder mount to shift it so that the shoulder arc is directly behind the rails rather than to the side of it? I don't want the camera like... in my chest, I want the camera above my shoulder, that's the whole point. I'd put the bit that slides onto the rods IN FRONT of the base plate for the camera.
Cheers
Old May 17th, 2008, 10:20 PM   #2
I don't have a photo handy but yes, you adjust the rails mount / arm so that it sits above (not directly) the shoulder mount so you can slide it on to the rods and position the shoulder mount "under" the rods. It's a pretty flexible system but I place it under the camera plate too for better balance.
mike
Michael Chenoweth is offline   Reply With Quote
Old May 18th, 2008, 08:24 AM   #3
Guest
Posts: n/a
Excellent, thanks :)
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
