Zoom / Focus controllers for JVC GY-HD series Pro HD camcorders - Page 4 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Remote Lens Controllers
Old November 21st, 2006, 08:01 AM   #46
Thank you Jack, your info was very helpful. From that part number it wasn't rocket science to guess the Canon part is HZ-FM15-G. M. ASY.
Local spare parts were able to source both these from Japan.
My cost for both the 13 and the 15 is about AU$500 including 10% tax & freight (thats about US$375 and I can get the tax back too).
Add the US$100 for the eBay part and I can control focus on both Fujinon and Canon lens now. Not free by any means but well under new price.
I also bought the JVC zoom controller on eBay as well, around half price and it works perfectly.
Guy Barwood is offline   Reply With Quote
Old December 21st, 2006, 02:05 PM   #47
Varizoom Pro-F zoom controller
I'm looking for a zoom controler to use on my HD100. Did anyone tried the Pro-F (http://www.varizoom.com/products/controls/vzprof.html) with the stock Fujinon lens of the HD100?
Diogo Athouguia is offline   Reply With Quote
Old January 2nd, 2007, 04:27 PM   #48
Has anyone used the Varizoom VZ-EFC on the JVC camera?
Has anyone used the VZ-EFC, remote focus controller on the HD100 OR HD110 camera?
Here is the link:
http://www.varizoom.com/products/controls/vzefc.html
Old January 2nd, 2007, 04:42 PM   #49
Moved from JVC Pro HD to Remote Lens Controllers.
What's neat about these zoom controllers is that they don't care what camera you're using. All that matters is the lens, whether it's Canon or Fujinon. Some controllers are switchable between Canon and Fuji lenses, and there are crossover cables available which will allow a Canon controller to work with a Fuji lens and vice-versa. The only communicating that the controller has with the actual camera body itself, is the Rec / Pause trigger and the video return button.
Old January 2nd, 2007, 05:02 PM   #50
Somehow I originally pasted the wrong link above to the wrong controller.
I have corrected it. Nevertheless, Chris's comments still apply.
This focus controller is fairly new and I can't find anyone with it in stock or even at Varizoom who has direct knowledge of using it.
It will control the lens from up to 50' and it has four presets in addition to manual control.
Old January 2nd, 2007, 05:17 PM   #51
Okay, now I get it -- the original link was a zoom controller, but you're right, the same thing applies here... it connects directly to the lens at its focus ring, so it doesn't matter which camera you're using with it. All that matters is the lens.
Old January 3rd, 2007, 06:15 AM   #52
This is excellent news, and relatively cheap
I wonder if it will work with the stock HD100 lens?
Thanks for this
Andrew
Drew Curran is offline   Reply With Quote
Old January 3rd, 2007, 09:28 AM   #53
Thanks for this
Andrew
I called varizoom and the person I talked to said that it does work with the JVC HD100, which I believe would mean the stock lens.
The unit adapts to two different barrel sizes of Fujinon lenses.
However, I have yet to speak to anyone who has acutally used the Varizoom unit.
Old March 14th, 2007, 03:03 PM   #54
I have a similiar one for my dsr300, in fact I have two, good solid units.
Lee Hopper is offline   Reply With Quote
Old March 14th, 2007, 05:32 PM   #55
It has an aluminum housing and is solid and hefty -- you can pretty much use it to hammer nails.
Old May 19th, 2007, 08:33 AM   #56
zoom / focus controllers for JVC GY-HD200
I have the JVC hdv-200 cam with the standard 16x lens that comes with it. I am looking for both zoom and focus/iris controllers I can attach to my lens.
One issue I need to deal with is . . . the cam is attached to the end of a 21 foot jib. So I need something that has long enough cables.
You guys got any suggestions? I appreciate any input! Thanks!
Ralph McCloud is offline   Reply With Quote
Old May 19th, 2007, 10:16 AM   #57
You could use one of the 8-pin Fujinon controllers made by Varizoom with this extension cable from Varizoom:
http://www.varizoom.com/products/acc...vzext8pin.html
Here are the controllers (the Fujinon 8-pin are near the bottom):
http://www.varizoom.com/controlsindex.html
All are available from B&H, a sponsor of dvinfo.net
Old May 20th, 2007, 08:09 AM   #58
lens controls
The zoom control would work, but the problem is the cable length for the focus controller. I don't think they make a cable over 20 feet for focus?? At least I can't find one!
Old May 20th, 2007, 10:29 AM   #59
Because the focus controllers like the one you found are mechanical devices, there is a limit. But, Varizoom has an electronic model which works pretty far. I've never used it, but maybe it's right for your purpose. http://www.varizoom.com/products/controls/vzefc.html
Tom Wills is offline   Reply With Quote
Old May 20th, 2007, 06:54 PM   #60
I own this one, and it would work fine. It's made for a jib. You can set 4 focus positions and go from one to the next and then back just by pushing a button. You can also adjust focus by twisting the knob, but the control is not real fine. The easiest is to use the presets. This unit will go a lot more than 20 feet.
(Note: on my Fujinon wide angle lens, I had to add a washer under the head of the screw that attaches the unit to the lens. The screw is a bit too long for my lens, but it works fine with the extra washer.)
Jack Walker is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Remote Lens Controllers
