#106 |
Bump into this thread as my Varizoom VZ-Rock stopped working after 1 year 2 months. One of the pins locking the spring mechansim fell out during the second use a year ago. Got a new replacement. Now the zoom level just stuck (won't spring back to level position) and the Record button just won't register from time to time. Actually very disappointed to VZ product.
I'm going to get the Manfrotto 521Proi
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
#107 |
Anyone using the Manfrotto 523PROi with the XH-A1 S model, I read where the controller zoom is slow to kick in .. is that right?
I'm looking to use one with the Miller Compass 15 head, and need to know what is the diameter of the top of the 523PROi handle thanks. Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated. |
#108 |
I am using it with my XH-A1s. The zoom rocket speed can be set at either progressive or fixed speed. It's all customizable.
#109 |
Thanks TC. So you're not having any trouble with slow zoom access times?
Checking around seems the diameter of the 523i pan handle is 19mm so I have to buy another one to fit the Compass head .. part number 522PB16. More bucks :( Cheers.
#110 |
low cost lanc controller for XH-a1
Found this on ebay....hype says it will work on the XH-A1.
The Canon controllers range from 170 to 350 bucks. this one is $39 ! Probably to good to be true. Has anyone purchased one of these...sure dont want to hurt my A1 by buying some off brand equipment. Heres the link |
#111 |
Sounds far to good to be true. Mine cost me about $270, slightly less than shown here Keene Retail Ltd but same Manfrotto model - better than the Canon ones.
Don't see how anyone could market a reliable LANC for $40 but I've been wrong before. |
#112 |
FWIW, this one works and is very compact. Zoom control only. http://www.bhphotovideo.com/c/product/361366-REG/Libec_ZC_3DV.html
#113 |
I'm surprised we haven't seen this earlier .. if the on screen display means camera LCD, depending what info it shows that could be handy.
It looks Ok but time on the web will tell if they last the distance .. stuff out of China is improving all the time. I've got this Manfrotto Keene Retail Ltd it's excellent and the rec review is great to have .. but I wouldn't mind if it was a bit smaller. Cheers.
#114 |
If it werent for being afraid I'd harm my A1, I would order and check it out.
A lanc is a passive device right? (no voltage sent to cam)....although it could "short" the battery power if wired incorrectly. Not worth trying the test. Thanks for the tips, Jeff |
#115 |
Hi Jeff,
I have bought of these guys before. Their items are not top quality and you'll get what you pay for. (CHEAP STUFF) Do yourself a favour and look into the Manforotto 521PROI lanc control. You wont be disappointed. Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e |
#116 | |
I bought one of this exact brand for my Canon XH-A1s. It works really well. I'm sure it isn't as well made as the other more expensive brands but I've used this one on countless occasions filming concerts and stage productions. I don't usually record to tape so I haven't used the record button at all, but the zoom is really smooth and the speed is adjustable as you are zooming. I'd say it's worth the investment. Richard |
#117 |
At 1/10 the cost, Im gambling on this unit. Surely it will work on either my A1 or GL1. Whats another $40 ha.
I can always get a pro model from B&H. Will post results to this thread when I try it out. |
#118 | |
I would love to know how it worked out for you. Thanks! Micky
Home: See "Work" :) Work: Canon XH A1, CS3/CS4/CS5/Final Cut Studio/Final Cut Express/Premiere Elements |
#119 |
the inexpensive one from b&h works absolutely GREAT !! i love it better than the Canon one at more $$$
"Two wrongs don't make a right, but three lefts do." |
#120 |
Hi Rodger! Thanks for the reply and info! I really appreciate it!
Is this the LANC you are talking about: VariZoom VZRock Variable-Rocker for LANC Camcorders VZ-ROCK B&H Do you use it with an XH-A1? Not as cheap as that Ebay one, but definitely cheaper than the other mentioned here. It would be interesting to know how that one compares to the Ebay one. :) Thanks again!
