#991 |
HP Touchsmart All-in-one Computer
Lightly used editing machine available for sale. Very good condition. Specs are as follows:
Intel Core i7 Quad Core 24" 1920x1080 screen 8 GB RAM Windows 7 (free upgrade to Windows 10) 1 TB Hard Drive Nvidia GT 425M graphics Logitech wireless keyboard/mouse Power supply Original Box Originally $1,200 Asking $699 /shipping included within U.S. Last edited by Brian Tori; December 28th, 2015 at 08:16 AM. Reason: extra info |
#992 |
Marshall V-LCD70XHB-HDIPT 7" LCD Monitor kit with Sony NP-F970 Battery, extras
This HDMI loop-through monitor was only used on a few indoor video shoots. Works great, like new. Comes with 12v power adapter, Sony L battery plate, Sony NP-F970 battery, hard case (originally used with a different monitor and has a few small dings, not bad though), HDMI cable, component cable and user manual. Asking $500. PayPal accepted.
-High Brightness 800 x 480 LCD panel -DSLR Ratio Adjustment -HDMI Auto Color Space and Ratio detect -Manual Gamma Adjustment -Adjustable Backlight -Image Flip -1/4"-20 mounts on all sides -Robust Colt power switch and rugged front panel -Variety of Markers, including user-adjustable -HDMI Loop-Through* -False Colorr On/Off -Peaking Filter On/Off -RGB Check Field / Field Detect -15:9, 16:9, 4:3, Pixel-to-Pixel modes -4 user-configurable function buttons -Scratch Resistant Protective Screen -RGB gain and bias control -Variety of User-Replaceable Battery Adapters available FROM THE MANUFACTURER: The V-LCD70XHB-HDIPT is a high brightness monitor with integrated HDMI loop-through. This highly-desired feature allows the camera operator to pass-through the HDMI video input from the V-LCD70XHB-HDIPT to another monitor for a client, director or crew/talent member to view on-location. This handy "all-in-one" solution bypasses the need for HDMI splitters, additional power sources and other requirements necessary to split the signal. The V-LCD70XHB-HDIPT monitor has been upgraded with even more features and versatility. Major features include HDMI pass-through, DSLR Ratio Adjustment, adjustable backlight and markers, HDMI Auto Color Space and Ratio detect, manual gamma adjustment, Image Flip, 1/4"-20 mounting on all sides, and a robust power switch. This portable monitor is the perfect solution for video professionals shooting outdoors or in bright lighting conditions. Don't be fooled by higher screen resolution or sizes. Our picture performance, feature set, customer service, and experience is why the industry's leading photographers, videographers, and camera operators prefer Marshall over the competition. Our product is designed, engineered, and assembled in the USA. This 7" monitor offers standard features including a wide variety of formats and markers, 4 user-configurable front panel function buttons, RGB Check Field / Field Detect, RGB gain and bias control, 4-pin XLR power jack, and optical grade polycarbonate screen protection. Two other major features include Marshall's industry leading FALSE COLOR and PEAKING Filters. These units also offer the ability to adapt up to nine different battery configurations for providing mobile operation in the field. This option provides flexibility when using different cameras or configurations. Last edited by Jim Nogueira; December 29th, 2015 at 12:56 PM. |
#993 |
Re: PXW-X70 Professional XDCAM 4K Installed 2 Extra Batteries 64GB SD
Sold. Thank you.
#994 |
Veydra Mini Prime 25mm T2.2 SONY E MOUNT-Imperial Focus Scale Lens with MFT mount
Veydra Mini Prime 25mm T2.2 SONY E MOUNT-Imperial Focus Scale Lens. Comes with MFT mount easy to change on lens $99 value. Asking $749, saving of $200!
DESIGNED FOR STILL PHOTOGRAPHY OR VIDEOGRAPHY DESIGNED FOR SONY E MOUNT AND MFT SERIES CAMERAS INCLUDES: ORIGINAL BOX ORIGINAL FRONT & REAR LENS CAPS Product Highlights Sony E Mount Lens for Cine-Style Shoots Supports 4K Recording Quality 80mm Front Barrel Diameter Constant Volume Focus 0.8 Pitch Gears 77mm Front Filter Threads Featuring an imperial (feet) focus scale, the Veydra Mini Prime 25mm T2.2 Sony E Mount Lens is a standard focal length lens for Micro Four Thirds cameras. It is well suited for 4K image capture and features an 80mm front barrel diameter. The lens features a constant volume focus design so the lens does not changed its physical size when changing focus, which makes it compatible with rod-mounted accessories such as matte boxes. It incorporates 0.8 pitch focus and iris gears, allowing it to interface with standard lens accessories, and the bright yellow dual focus scales allows the lens to be easily read from either side of the lens. A 77mm filter thread allows you to attach an optional filter directly to the front of the lens. A cinema lens with a precise 300° barrel rotation T-stop range of 2.2 to 22 Minimum focus distance of 10.0" Paypal Preferred. Shipping included. Certified USPS. |
#995 |
Re: Marshall V-LCD70XHB-HDIPT 7" LCD Monitor kit with Sony NP-F970 Battery, extras
Price dropped to $500.
#996 |
Four Tiffen filters
I bought these filters but never used them.
Tiffen 62mm Variable ND Filter http://www.bhphotovideo.com/c/product/821125-REG/Tiffen_62VND_62mm_Variable_Neutral_Density.html Tiffen 72mm Variable ND Filter tiffen 72vnd | B&H Photo Video Tiffen 62mm Circular Polarizer tiffen 62cp | B&H Photo Video Tiffen 72cp http://www.bhphotovideo.com/c/product/56636-REG/Tiffen_72CP_72mm_Circular_Polarizing.html The ND filters are still in the tissue. I just don't need the filters, so if you'd like to make a reasonable offer for one or a combination, just let me know. I have pictures but I'm missing a security token in order to upload to the forum.
What happens if I push the 'Red' button? |
#997 |
Sennheiser G2 Wireless mic with plugin tansmiter - C band
Sennheiser Evolution G2 100 Series wireless lavalier with plugin transmitter
This system is C band (740-776 MHz, illegal in USA) EK 100 G2 receiver SK 100 G2 body pack transmitter SKP 100 G2 plugin transmitter ME2 Microphone w/ windscreen (the cord is frayed where it meets the connector, see pic) XLR output cable Camera shoe adapter Shows signs of use, but is still good working order $300 USD plus shipping Last edited by Yossi Margolin; December 30th, 2015 at 07:24 AM. |
#998 |
Panasonic GH3/Lumix G 12-35mm wide lens
Both in great condition. 1 owner (me) non-smoker.
1. Panasonic Lumix DMC-GH3 Mirrorless Micro Four Thirds Digital Camera (Black) 2. Panasonic Lumix G X Vario 12-35mm f/2.8 Asph. Lens for Micro 4/3 (Black) Original retail boxes included. Sold as a package. Asking $1200 US (Paypal preferred) |
#999 |
Sennheiser G2 Evolution Wireless Microphone System
Sennheiser G2 Evolution Wireless transmitter and camera mount receiver (740-776 MHz) "C" Frequency Range) with high-quality Sennheiser lavalier microphone.
Closed my Monroe LA studio. So offering this gently used equipment. Never abused, never dropped or damaged in any way. Does not include the plug-in transmitter. Asking $400 plus shipping. |
#1000 |
Bogen Manfrotto 3245 Tripod with 503 Fluid Head
Closed my Monroe LA studio, I have the following video support equipment for sale:
This equipment has been gently used and is in good working order and condition unless so stated. Bogen Manfrotto 503 - Fluid Head w/577 quick- release mount, on Manfrotto 3246 Tripod (Chrome Legs) Also, Weifeng WT-600 Tripod Dolly. Folds down to 22.5", Weighs 5.3 lbs. Adjustable foot locks to lock the tripod down. Wheel locks on all 3 wheels. (Retail $99) offered for $50 And Libec Zoom Controller. Mounts on Tripod arm for smooth start/stop and zoom. For Panasonic and Lanc controlled cameras. (Retail $79) offered for $40. Photos to come. |
#1001 |
Re: Blackmagic Pocket Cinema Camera with Nikon Speedbooster Kit
Cage and filter no longer available. I will add a complimentary BRAND NEW 5th battery for a commitment to purchase.
#1002 |
The price now includes free USA shipping. This monitor sells new for around 1K for the monitor only, no battery plate, battery, hard case or cables.
#1003 |
Re: Dylan's Mega Bargain Blowout Summer Yardsale!
Bump for the end of the year!
Need to rent camera gear in Vancouver BC? Check me out at camerarentalsvancouver.com |
#1004 |
Re: Sigma Art 30mm Lens f/1.4 Canon EF - Great Condition
Bump. New Price $300
