Private Classifieds listings from 2010 - Page 180 at DVinfo.net
Old June 28th, 2010, 10:06 AM   #2686
Fs bogen 516
Manfrotto 516 Pro Video Fluid Head
Pro Video Tripod Head
Fluid HeadQuick Release
Supports 22 lbsFriction ControlPan & Tilt Axis
Counter Balance SpringBubble Level
Just got it back from Bogen yesterday freshly serviced. I have no use for this head anymore and have decided to sell.
$500
Ivan George is offline
Old June 28th, 2010, 10:07 AM   #2687
Sekonic L-758c
Like new Sekonic meter includes box, manuals, cable & software. I purchased it for 750 plus shipping.
$650
Sekonic has done it again!!! The Sekonic L-758C Cine Light Meter is the world's first multi-function light meter that can be programmed to match and be calibrated to the sensitivity of your digital camera sensor or type of film for perfect exposure control. They have produced an incredible meter that more than meets the needs of the photographic community. This full-featured meter will definitely make everyone happy as it is loaded with every imaginable feature - and then some...
The L-758Cine differs from the L-758DR model in that the 758Cine has expanded cine speed (fps) 1 thru 1000, Lux 0.63 to 190,000, Foot-Candle 0.10 to 180,000, Cd/m to 190,000, Foot-Lambert 0.07 to 190,000 and Preset filter compensation values (including Kodak Wratten filter number)
Expanding on the unqualified success of the L-558R, Sekonic has taken the next step and designed a meter that offers advanced features such as Spot/Incident measurement modes, flash/ambient measurements, flash analyzing, PocketWizard wireless triggering (usable with optional module), plus Exposure Profiling, Pre-Exposure warning, 14 selectable custom settings, and much more. This weather-resistant meter not only meets the needs of the digital community but can also serve the cinema community.
The L-758C measures light beyond the capabilities of your camera and ensure repeatable accurate and consistent measurements. In addition, the dynamic range of a particular digital camera or film can be stored, recalled and displayed. Using the USB transfer cable (included) and the Sekonic Digital Input and Transfer software (included), a digital camera or film's exposure profile can be uploaded from a computer (Macintosh or Windows) to the L-758C.
Up to three different digital camera or film exposure profiles can be saved and quickly retrieved with a touch of a button. With its Pre-Exposure warning indicators and adjustable mid-tone settings, the L-758C puts the power of digital exposure control in the palm of your hands.
When you need to take a light reading - think Sekonic...
Important
To comply with local broadcast regulations, Sekonic wireless systems sold in the various markets around the world are designed to operate at different frequencies. When purchasing and/or installing a transmitter module or using the meter with a receiver, be sure that the meter, module and receiver are designed to be used in your location and use the same frequency.
The FCC designation indicates the meter and module are designed for operation in the USA/North American market. Frequencies: CH 1 to 16: 344.0 MHz; CH 17 to 32: 346.5 to 354.0MHz
The CE designation indicates the meter and module are designed for operation in European countries. Frequencies: CH 1 to 16: 433.62 MHz; CH 17 to 32: 434.22MHz
The wireless flash triggering system used in Sekonic meters consists of two parts that are designed to be used together and operate only at a specific frequency. Do not install a CE marked module into an FCC marked meter or FCC marked module into a CE marked meter as this will produce a unit that is not compatible with either frequency.
• The L-758Cine model has expanded cine speed (fps) 1 thru 1000, Lux 0.63 to 190,000, Foot-Candle 0.10 to 180,000, Cd/m to 190,000, Foot-Lambert 0.07 to 190,000 and Preset filter compensation values (including Kodak Wratten filter number)
Exposure Profiling
Programmable to respond to light exactly like your digital camera or type of film; The L-758C can be programmed to perfectly match the sensitivity of a digital camera senor or type of film for perfect exposure control; In addition, the dynamic range of the digital camera or film can also be stored; Up to three Exposure Profiles (digital cameras, types of film, file type or file type) can be stored and recalled quickly and easily. Exposure profiles can be created for the following measuring modes:
Reflected measurements (calculated from ISO 3 to 8000)
Ambient measurements (calculated from ISO 3 to 8000)
Incident measurements (calculated from ISO 3 to 8000)
Flash measurements (calculated from ISO 3 to 8000)
Four Meters In One
Independent programming of Flash, Ambient, Incident and Reflected measuring modes customized to your digital camera or type of film
Working together (Incident and Reflected modes)
Measured values can be memorized and retained in both reflected and incident measuring modes; For example: A incident reading can be retained and displayed as a diffused mid-tone on the analogy scale (f-stop or EV scale), at the same time as reflected spot reading of a highlight or shadow can be measured and memorized; The result is a Highlight, Mid-Tone and Shadow measurement displayed on the meter's analogy scale
Spot with Digital Display
The L-758C Cine features a rectangular 1° parallax-free spot viewfinder; In dim or bright light situations, the L-758C Cine's spot viewfinder displays f/stops, shutter speeds and more; The built-in spot meter measures both reflected ambient, flash or combined lighting
Pre-Exposure Warning
Displays and alerts when a measured value exceeds your digital cameras (or type of film) dynamic range
Super Sensitive Flash Metering
Measures light beyond the limits of any camera (reflected flash measurements as low as f-2.0 (ISO 100)
1° Spot with Digital Display
Rectangular 1° spot viewfinder with vivid display
Mid-Tone Adjustment
The Mid-Tone button acts as an exposure shift, moving the highlight or shadow within the dynamic range of the digital camera or type of film; Once the desired high light or shadow setting is selected, the pre-exposure blinking alert icon stops flash, indicating that the value is within the recordable range
Retractable Lumisphere
A built-in adjustable incident dome (Lumisphere) provides full measuring in the standard position or when retracted, provides cosine-corrected light readings for individual light source measurements or flat artwork
Analyzing Function
Simultaneous reading of flash and ambient light is analyzed and displayed
Combined readings of flash and ambient
Percentage of flash in the total exposure
Simultaneous display of flash, ambient and combined readings on the analog display
Exposure, Calibration and Filter Compensation
Independent incident and reflected exposure compensation of up to +/-9.9 EV can be easily set for custom film exposure corrections or for bellows extension factors; With the calibration, compensation setting of +/-1.0 EV, matching built-in camera meters or other handheld meters is a snap; There is even a filter compensation setting of +/-5.0 EV for filter factor compensation
Data Transfer Software
Compatible with both Windows and Macintosh computers, the Sekonic Data Transfer Software automatically calculates the entered test data from a digital camera and creates an exposure profile; These profiles contain exposure characteristics for Flash, Ambient, Incident and Reflected exposure modes from ISO 3 to ISO 8000; In addition, the dynamic range at all ISOs are calculated and stored; Exposure profiles are transferred via a USB cable (included) from the Data Transfer Software (included) directly into the L-758C. Once the data is completely transferred to the meter, it is automatically calibrated and programmed for the specific digital camera sensor or film loaded in its memory
Dual ISO Settings
The L-758C offers the flexibility of taking a single measurement and displaying the f-stop and shutter speed for two different ISO film speeds, such as negative film and Polaroid proofing film; The second ISO setting is also ideal for calculating exposure compensation such as filter factors or bellows factors, without having to change the original film speed settings
All Weather Design
All buttons, switches and compartments are sealed and the meter housing has been constructed with durable, rugged conditions in mind; Ideal for shooting in sandy, rainy or humid conditions
14 Custom Settings
The custom settings mode provides a quick and easy setup of individual meter preferences. The L-758C features and modes can be turned on or off, as well as modified to fit the needs of the individual using the meter
Memory All Clear
Memorized values can be all cleared or the last memorized value can be deleted (backspace clear), in addition, individually selected values can be selected and cleared
Old June 28th, 2010, 10:15 AM   #2688
Bogen 100mm Bowl Interface
Bogen 3114 100mm Bowl Interface
$50
Old June 28th, 2010, 10:20 AM   #2689
Ewa-marine Underwater housing for XH and XL series cameras $600
This unit cost $1200 new - and is in excellent condition. Makes your productions look like a million bucks and you can bill clients for cool underwater shots. Now selling for $600
The VXL2 is the 10 meter / 30ft depth housing for the Canon XL 2 digital and the Canon XL H1 Series HD camcorders. It is manufactured from double laminated PVC and has an integrated, optically neutral flat glass port.
Perfect for snorkelling or shallow diving, sandy, dusty, humid or foul weather conditions this housing will give your camera the best possible protection whilst being fully operable.
The pouch supplied with the housing allows weights to be added for perfect buoyancy under water.
It has a pair of non-corrosive and seawater resistant clamping rails which fit together for perfect sealing. They tighten by means of knurled thumb screw knobs. It is supplied in a handy black and yellow carry-case which has a water-proof interior and zippered side-pocket.
Including in the photos is a shot from a feature that this bag was used once on. The film was in Tribeca Film Festival and the film got sold - underwater shots got the critics jumping!. Buy this housing and do a great underwater scene.
http://www.dvinfo.net/forum/attachme...nderwater2.jpg
http://www.dvinfo.net/forum/attachme...nderwater1.jpg
http://www.dvinfo.net/forum/attachme...sing-under.jpg
Director: http://www.mediathreat.com
John Threat is offline
Old June 28th, 2010, 10:46 AM   #2690
Sold.
thank you!
Brian Young - Los Angeles - www.FlacaProductions.com
F800, F5, FS7, A7s
Brian T. Young is offline
Old June 28th, 2010, 11:59 AM   #2691
Sold to Adam for $1700.
Man Yip is offline
Old June 28th, 2010, 12:38 PM   #2692
Message sent on video head possibly 3221 legs too
C.M. Pritchett
Colin Pritchett is offline
Old June 28th, 2010, 01:22 PM   #2693
Redrock M2 Encore, MicroXflip, Nikon mount
Hi,
I have a Redrock M2 Encore 35mm adapter for sale. It comes with rails, nikon mount, microXflip. It's in great condition and works perfectly. It includes the full indie bundle found at:
http://store.redrockmicro.com/Catalog/M2EncoreBundles/M2EncoreIndieBundleMicroX$
$1400 obo. I will ship to anywhere in the US. Local pickup in Los Angeles. You can pay with paypal.
Let me know if you have any questions. Thanks!
Private Classifieds listings from 2010-imag0214.jpg   Private Classifieds listings from 2010-imag0206.jpg
Private Classifieds listings from 2010-imag0209.jpg   Private Classifieds listings from 2010-imag0220.jpg
Jeremy Hayward is offline
Old June 28th, 2010, 01:46 PM   #2694
JVC HD100 for parts
If anybody has an old JVC HD100 that may or may not work, I am specifically interested in the XLR audio input sound board. Please let me know I am interested in buying.
Clay Morton is offline
Old June 28th, 2010, 02:05 PM   #2695
Is there any interest in this item at all?
Please respond with any thoughts you have...
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline
Old June 28th, 2010, 03:33 PM   #2696
Britek Fluorescent Lighting Kit $400
Purchased less than a year ago. In great condition, I am selling because I plan on traveling abroad for a year or so.
Model: Britek 2SB 1850 (Priced at $599.99 brand new)
Britek 1604 #PE9040K #PE9020K #PE9009-4K #PE9040 Cool Light Bank Kit
Includes
2 BriTek Light Banks (4-way power adjustable)
8 Fluorescent Lamps 50W at 5500K
2 Softboxes
1 Fluorescent Hair light 250 W Bulb at 5100K with barn doors
1 Boom Kit for Hair light
3 Light Stands
Carry Cases
If you are interested, drop me a line at:
contact@dutchsimpson.com
Private Classifieds listings from 2010-p2010519.jpg   Private Classifieds listings from 2010-p2010521.jpg
Private Classifieds listings from 2010-p2010522.jpg   Private Classifieds listings from 2010-p2010525.jpg
Dutch Simpson
www.dutchsimpson.com
Dutch Simpson is offline
Old June 28th, 2010, 04:40 PM   #2697
Canon G10 - Great Condition
Anyone have a Canon G10 in excellent, like new condition that they are willing to part with?
I'm looking to buy one for a project.
Let me know. Thanks.
Michael Galvan is offline
Old June 28th, 2010, 06:43 PM   #2698
Wibo, may I ask what camera are you upgrading to?
Thanks.
Alex Raskin is offline
Old June 28th, 2010, 11:08 PM   #2699
Canon XH-A1 + SGBlade Adapter Combo
This combo is perfect for run-n-gun style shooting and produces AMAZING film-like images. Many users agree this setup is just gorgeous, thanks to sgblade.
You can view samples at my website Self Motif : Joe Kamimura + Main
PACKAGE INCLUDES:
-XHA1 - with LCD Flip hack, wonderful condition
-All components and accessories (box, cables, charger, body caps, filters, remote etc.)
-1 Canon 5200mAh battery + 2 after market 6000mAh batteries
-20 JVC tapes - brand new
-Approx. 100 hours of use
-SGBLADE Non Flip
-Rods support system, Rotorazor 2, Nikon Mount, flight case, 72-77mm step up ring
TOTAL PACKAGE: $3000
or split up
XHA1 - $2300
SGBLADE - $900
PM me for offers
Joe
Joe Kamimura is offline
Old June 29th, 2010, 03:34 AM   #2700
Alex,
We're not upgrading. We simply have not enough work for the SI-2K. It's in the case doing almost nothing...
Wibo
Wibo Broek is offline
