#2206 |
All of my video / audio gear!
We slowly transition from wedding videography to photography and since last fall I haven't touched my video gear, so it's time to give it a new home. I will be in SoCal all next week so I will be able to bring it down to sell there if you would like to meet. Everything is used but functions perfectly.
Sony Z1U $2100 - All orignal accessories - Tamrac Soft Case - AT897 Mic with cable - Two extra Impact 970 batteries Sony A1U $1300 - All original accessories - Three extra Sony NP-QM71D batteries Century Optics Fisheye / Wide angle adapter 58mm w/ thread adapter for A1U $150 - Missing rear lens cap Sennheiser ew100 $275 - Transmiter belt pack, receiver, & XLR transmitter - Lav mic, miniphone adapter & XLR adapter (2) Manfrotto 3182 tripod with 501 head $275 each Audio Techica AT8202 in line attenuator $20 Lot of misc. cables and adapters $25 - Includes at least (1) XLR splitter, (3) XLR gender benders, (2) XLR to RCA adapters, (2) XLR to 1/4 adapters Email me at patrick@patrickpike.com if you have any questions!
www.patrickpikephotos.com |
#2207 |
Hello
I have the Juicedlink cx231 http://www.bhphotovideo.com/c/product/563070-REG/juicedLink_CX231_CX231_Audio_Mixer_and.html I rarely use. Great shape It retails for 299$Us I could part with it for 230$ plus shipping Paypal? let me know J |
#2208 |
Sold!
THIS ITEM IS SOLD!
Thank you very much. |
#2209 |
These items have been sold.
Martin Pauly |
#2210 |
The item has been sold.
Martin Pauly |
#2211 |
pictures on the cards too please
#2212 |
Sennheiser
Email sent regarding wireless.
Reed Gidez |
#2213 |
item has been sold
Jawad Mir / Cinematographer . Filmmaker Film Style Weddings http://www.filmstyleweddings.com Jawad Mir http://www.jawadmir.com |
#2214 |
I should add the Sennheiser's are in the C band 740-772.
#2215 |
Luc, how many discs do you need? I bought 25 used discs quite cheap when I bought my F330 but I found out I only need a few discs. I'm willing to sell some to you at the same price as I bought them (€10/p. incl VAT).
#2216 |
Email sent
#2217 |
Hey Rob,
Out of curiosity.. what smaller mic setup are you going to with the HMC150? Thanks, Scott |
#2218 |
Sony PMW-EX1
EX1 with 2-8gb SXS Cards and one 16gb. One USB SXS card reader tha allows you to dump footage into your laptop (value $300). Two Batteries- BP-U30 and BP-U60 (60 gives over 2 hours of filming). Has UV filter and I will include the 1620 Pelican case that I bought for it (http://www.bhphotovideo.com/c/product/179087-REG/Pelican_1620_020_110_1620_Case_with_Foam.html). Camera is in Excellent condition. Hour Tally @ 240 hours. http://www.flickr.com/photos/dylanrm...n/photostream/ (not all items included in pics)
Price lowered! $4,700 .................................................................................................... ................. Technical Specifications: Mass Approx. 2.4 kg (5 lb 4 oz) (body) Approx. 2.8 kg (6 lb 2 oz) (with lens hood, large eye cup, BP-U30 battery, one SxS PRO memory card) Dimensions (W x H x D) 178 x 176 x 311.5 mm (7 1/8 x 7 x 12 3/8 inches) without projection Power requirements DC 12 V Power consumption Approx. 13 W (while recording, with color LCD OFF, 1920 x 1080/59.94i mode) Operating temperature 0 to +40 °C (+32 to +104°F) Storage temperature -20 to +60°C (-4 to +140°F) Continuous operating time Approx. four hours with BP-U60 battery Approx. two hours with BP-U30 battery Recording format Video MPEG-2 Long GOP[br}HQ mode: VBR, maximum bit rate: 35 Mb/s, MPEG-2 MP@HL SP mode: CBR, 25 Mb/s, MPEG-2 MP@H14 Audio Linear PCM (2ch, 16-bit, 48-kHz) Recording frame rate NTSC setting HQ mode: 1920 x 1080/59.94i, 29.97P, 23.98P, 1280 x 720/59.94P, 29.97P, 23.98P SP mode: 1440 x 1080/59.94i PAL setting HQ mode: 1920 x 1080/50i, 25P, 1280 x 720/50P, 25P SP mode: 1440 x 1080/50i Recording/Playback time HQ mode Approx. 50 min. with SBP-16 (16 GB) memory card, Approx. 25 min. with SBP-8 (8 GB) memory card SP mode Approx. 70 min. with SBP-16 (16 GB) memory card, Approx. 35 min. with SBP-8 (8 GB) memory card --Lens-- Zoom ratio 14x (optical), servo/manual selectable Focal length f = 5.8 to 81.2 mm (equivalent to 31.4 to 439 mm on 35 mm lens) Iris F1.9 to F16 and Close, servo/manual selectable Maximum relative aperture 1:1.9 Focus AF/MF/Full MF selectable 800 mm to infinity (MACRO OFF), 50 mm to infinity (MACRO ON, Wide), 735 to infinity (MACRO ON, Tele) Image stabilizer ON/OFF selectable, shift lens Filter thread M77 mm, pitch 0.75 mm (on lens) --Camera-- Pickup device 3-chip 1/2-inch type Exmor CMOS Effective picture elements 1920 (H) x 1080 (V) Optical system F1.6 prism system Built-in filters ND filter OFF: Clear, 1: 1/8ND, 2: 1/64ND Sensitivity (2000 lx, 89.9% reflectance) F10 (typical) (1920 x 1080/59.94i mode) Minimum illumination 0.14 lx (typical) (1920 x 1080/59.94i mode, F1.9, +18 dB gain, with 64-frame accumulation) S/N ratio 54 dB (Y) (typical) Horizontal resolution 1000 TV lines or more (1920 x 1080i mode) Shutter speed 1/33 to 1/2000 sec. Shutter angle 180, 90, 45, 22.5, 11.25 degrees Slow Shutter (SLS) 2-, 3-, 4-, 5-, 6-, 7-, 8-, 16-, 32-, and 64-frame accumulation Slow & Quick Motion function 720P Selectable from 1 to 60 fps as recording frame rate 1080P Selectable from 1 to 30 fps as recording frame rate --Audio performance-- Sampling frequency 48 kHz Quantization 16 bits Headroom 20 dB Frequency response 20 Hz to 20 kHz, +3 dB/-3 dB Dynamic range 90 dB (typical) Distortion Less than 0.1% (with input level of -40 dBu) --Signal inputs/outputs-- Audio input XLR-3-pin (female) (x 2), line/mic/mic +48 V selectable Mic: -8 dBu to -65 dBu (reference level) Line: +4 dBu A/V output AV multi (x 1) Audio: -10 dBu (reference level), 47 kÙ Analogue composite: 1.0 Vp-p, 75 Ù unbalanced S-Video: Y: 1.0 Vp-p, 75 Ù unbalanced, sync negative Component output Mini D (x 1), Y: 1.0 Vp-p, 75 Ù, Pb/Pr: 0.7 Vp-p, 75 Ù SDI output BNC (x 1), HD-SDI/SD-SDI selectable i.LINK input/output IEEE1394, 4-pin (x 1), HDV stream input/output, S400 USB Mini-B (x 1), USB 2.0 High-speed Headphone output Stereo mini-jack (x 1), 16 Ù, 30 mW Speaker output Monaural, 300 mW DC input DC jack Battery input 5-pin --Built-in LCD monitor-- 3.5-inch* type colour LCD monitor, approx. 921000 effective pixels, 640 (H) x 3 (RGB) x 480 (V), 16:9, hybrid type --Viewfinder-- 0.54-inch* type colour LCD, 1120 (H) x 225 (V), 16:9 --Built-in microphone-- Capsule type Omni-directional stereo electret condenser microphone Frequency response 50 to 15000 Hz --Media slot-- Type ExpressCard/34 (x 2) Interface ExpressCard compatible The PMW-EX1 is truly an innovation in compact camcorder development. Based around the popular hand-held camcorder design, the new camera offers enhanced workflow benefits over existing tape-based camcorders coupled with a superior picture performance, which overall provides camera operators maximum flexibility in whatever style of production is chosen. Enhanced Workflow Innovative solid state recording with SxS PROExpressCard memory cards offers the following benefits: Compatible with industry-standard ExpressCard interface available on most modern laptops No time lost to tape loading Robust storage media, impervious to shocks and vibrations Small, high capacity recording media offering over 2 hours of continuous HD content across 2 x 16GB cards. Common interoperability with HDV and XDCAM so ready to use immediately with most existing NLE. No need to worry about accidentally overwriting precious content Write and Re-Writable media with no degradation in picture quality Thumbnail images representing key scenes can be browsed and instantly accessed using on-camera colour screen ' Essence Mark' key scenes at the touch of a button No frantic fast-forward/rewinding to find the clips you want to review Non-proprietary media manufacture Supplied with Clip Browser Software for viewing and copying clips to HDD, DVD or Blu-ray Disc. Superior Picture Performance Newly developed Exmor™ CMOS processors offer true 1080 x 1920 resolution: Large ½ inch sensors for excellent sensitivity and depth of field characteristics Full 1080 x 1920 effective pixels Low power consumption compared to CCD technology 1080 / 720 switchable for international programme production Professional 1/2inch HD Lens The PMW-EX1 not only features an exceptional ½ inch Fujinon lens, but also introduces a uniquely flexible control system designed to appeal to both broadcasters and videographers 14x Fujinon Professional HD lens Unique focus operation offering full manual focus with absolute focus operation similar to the lens focus on an interchangeable lens or manual/auto focus operation as per standard handheld cameras AutoFocus Assist ensuring focus position can be altered Manual Focus Assist to ensure optimum focus at all times Exciting and Creative Recording Modes The PMW-EX1 is the first compact camcorder to carry the legendary CineAlta brand, which represents optimisation for feature film production and specifically support for 23.98P recording capability - the standard frame rate for feature film production. Alongside this, there are a myriad of creative recording modes available including: Slow and Quick motion offers a range of frame rates produced within the camera and available for instant review in the field New shutter setting emulates filmic operation Cine Gamma curves offer further filmic options for production Frame and Interval recording offers further creative scope for animation and extremely quick motion effects Slow Shutter for clear images in low-light environments Last edited by Dylan Morgan; May 23rd, 2010 at 12:23 PM. |
#2219 |
Just received the nanoFlash and is in perfect condition just as listed.
Thanks James, Garrett |
#2220 |
Still available... accepting offers.
