Private Classifieds listings from 2009 - Page 261 at DVinfo.net
Old August 9th, 2009, 02:41 AM   #3901
Cinebag CB-22/CB-25
Need one ASAP.
Will also take anything that can be carried onto a plane and hold a Camcorder, DSLR, and laptop.
Randy Panado is offline
Old August 9th, 2009, 07:57 AM   #3902
iRiver 795, New
Purchased the unit a while ago, checked its operation 3 mos. ago; fully functional. It is iRiver 795 w 256 mgb of memory, more than enough for a wedding. The unit was new in the package w Quick Start Guide, Operating manual, Music Manager manual & software on CD.
Bought it to record couples vows at wedding, never used it. This is one of the units that an electret lavaliere mike will work with. All for $65- postage included.
Bill Wilson is offline
Old August 9th, 2009, 09:25 AM   #3903
Wasn't sure. Sorry.
Nicole
Nicole Hankerson is offline
Old August 9th, 2009, 09:30 AM   #3904
Price lowered to $3,800!
(plus shipping)
Bryan Gilchrist is offline
Old August 9th, 2009, 11:47 AM   #3905
Originally Posted by Vito DeFilippo View Post
Hi Dave,
It's an ifp-899. I can tell it's not the screen, but a connection somewhere, cause if I press on the lcd, some of it comes back to life. I took apart a dead one I had to see if it would give me any clues, but as you said, it was tough to disassemble, and I didn't want to destroy the other one trying to fix it.
Don't knock yourself out, by any means. I just thought maybe you had come across this before.
Thanks for the reply. Much appreciated,
Vito
Definitely seen the problem before, including the intermittent if you press on the shell.
I suspect it's actually a bad screen, rather than in the ribbon cable or connections - it's a very complex assembly (don't know if you got the screen removed from the mainboard or not to see what under it?). If it IS in the actual screen, the only way to repair it would be to replace the whole screen/ribbon cable assembly. Strangely not a single one of the ones I've got has any lines that are "off" to experiment with! BUT I can see about removing a screen assembly - I have an idea if how it might be done, but it may take a custom attachment to a soldering iron, and even so, the ribbon cable is awfully delicate. IF I can sucessfully remove one, the "transplant" shouldn't be difficult.
In the end, if the display is readable (usually is, even with a few lines flaking), probably better to just use it as is.
Dave Blackhurst is offline
Old August 9th, 2009, 11:56 AM   #3906
Originally Posted by Randy Panado View Post
I have an 8 series that has an audible hiss associated with all the audio files. My other one of the same model/settings/firmware doesn't have it. Do you know of any repairs or tricks for that?
I'll forward this link to a friend looking for some irivers as well.
Thanks for giving us first crack :)
First thing I'd double check is that the line/mic settings are the same in the menus - I seem to recall that the wrong settings can be a bit noisier, and there are several settings. Sounds like you've looked at that already, but that's the "easy fix"...
If that's not it, the likely cause is a faulty daughterboard, a tiny little board that sits under the mainboard and contains all the I/O circuitry... and a royal pain to get to unless you know the disassembly tricks. I don't think I have a "donor" that has a usable board, but I'll double check. I think the only 8 series I have that is "dead dead" was already scavenged for usable parts, but I'll check and let you know!
Old August 9th, 2009, 12:49 PM   #3907
still available?
if you don't see "item is sold" in this thread... it's still for sale!
Greg Chisholm is offline
Old August 9th, 2009, 05:07 PM   #3908
Or trade: steadicam pilot vlb for advantajib...
I am looking to trade my pilot listed on this same site for a dykortech advantajib... i would like to acquire the full kit with extensions cables and maybe even a 528xb tripod.
just putting it out there :)
Greg
Old August 9th, 2009, 07:06 PM   #3909
Thought I had it sold, still available. $1400
Jason Davis is offline
Old August 9th, 2009, 08:34 PM   #3910
Hey Dave,
Yep, that's pretty much what I had concluded. I've resigned myself to just never changing the settings for as long as it lasts. I can at least tell when it's recording, so it does the job for now. Too bad there's not an easy fix.
Thanks for your feedback and suggestions. Hope your sale goes well.
Cheers,
Vito
http://www.nosmallroles.com
Vito DeFilippo is offline
Old August 9th, 2009, 08:38 PM   #3911
taken off for sale
Not for sale
pulled
Thankyou
Doug
Doug Tessler is offline
Old August 9th, 2009, 08:42 PM   #3912
pricing for one 310.00 including shipping
I found one new on the internet with free shipping and accessories for only
310.00
Doug
Old August 9th, 2009, 08:46 PM   #3913
Email sent this morning. Still available?
Matt Trubac
Matt Trubac is offline
Old August 9th, 2009, 09:39 PM   #3914
Canon HV20
Canon HV20 with low use - less than 5 hours. I bought this to use as a deck for my XHA1 but ended up with a Firestore so I rarely capture tape.
Does have one small surface scratch on the exterior, otherwise perfect. Comes with (1) battery and charger.
$450 obo.
jonah@efmarton.com
Private Classifieds listings from 2009-9fcv0584.jpg   Private Classifieds listings from 2009-9fcv0586.jpg
Jonah Bierlein is offline
Old August 9th, 2009, 09:42 PM   #3915
Matthews M25 Tripod
Matthews M25 Tripod in good condition with case and extra feet.
$125. obo
jonah@efmarton.com
Private Classifieds listings from 2009-9fcv0587.jpg   Private Classifieds listings from 2009-9fcv0588.jpg
