NRG Varalux Pro and wall power?
I was curious if there is a way that might enable me to run my NRG Varalux Pro off of power from a wall outlet instead of my battery belt?
Location: Central North Carolina (Raleigh, Durham, & surrounding areas)
Maybe...you'll need a power supply that can provide about 8 to 10 amps at 12 volts. It might be expensive! You might try a boat battery instead. You'll get better deep cycle discharge capabilities and you should have plenty of current to keep the light going for quite a while. You can get a plastic case with handles on it at your local boat equipment supplier. Add the proper connector (xlr4 or cigar) and you're in business!
Good luck! Mark Ok, based on George's response below, maybe I need to clarify. The power supply he refers to will indeed run the Varalux Pro light. It won't however, be capable of powering it at full power. As I said above, you'll need at least an 8 amp supply to get the full 100 watts. M Last edited by Mark Holland; April 12th, 2007 at 02:00 PM. Reason: Clarification |
sure can, get a 120 volt ac to 12 volt dc power supply. Radio Shack and other vendors have these for a reasonable cost. For convenience I have the power supply with a cigarette plug. Be sure the supply is rated for 3 amps or higher.
My nrg light is the xlr plug so I soldered an adapter from an old cell phone charger to connect form the cigarette plug of the power supply to the xlr of the light. hope this helps |
#4 | |
http://www.adorama.com/KD12VAC1245.html http://www.adorama.com/KD12VAC12DC.html I also have the XLR VAralux Pro and was going to use this jumper for XLR to Cigarette plug conversion. http://www.adorama.com/NR0471603.htm...4716&item_no=3 |
#5 | |
#6 | |
"You may power your Varalux-Pro from a wall outlet if you use a power converter to convert the 120V AC to 12V DC. Just make sure the polarity matches that of the Varalux to prevent reverse polarity that would damage your Varalux. If you have a 4pin connector on your Varalux, the #4 pin is positive and the #1 pin is negative. If you have a cigarette lighter connector on your light, the outer post is negative and the tip is positive. It is imperative that the polarities match, otherwise, the capacitor in the Varalux will blow and will need to be replaced." Would the Varalux Jumper work in this case if I had to use Cigarette to XLR connections? |
#7 |
Looks like it should. Just to be positive, check it with a meter before you use it. If you're not sure how to do that, I'll be glad to talk you through it. (Sorry, no insult to your abilities intended, I just don't know your skill level.)
Oh, and I'm not sure if your light has a male or female connector, so I can't say for sure that the adapter you gave the link for is THE adapter you need. Ok I looked it up. It seems the light has a 4 pin MALE XLR connector, so the adapter you linked looks like EXACTLY what you'll need. |
#8 |
Actually just purchased this from Adorama.
NRG Power Station http://www.adorama.com/NR12910014.html It's small enough for travel, and gives me the option of both XLR or Cigarette ports. Also being NRG it's wired properly for my Varalux light. It will output 8.3 amps of power, so I can run my Varalux light at 100 watt power if needed. Expensive, but will do the trick nicely. |
#9 | |
That units looks nice, it outta do the trick for you! Good luck! |
