Frezzi Mini-Fill power question at DVinfo.net
Photon Management
Old January 19th, 2007, 08:40 PM   #1
Hi everyone,
Let me first say that I don't have a clue about all the numbers and techincal stuff associated with electrical components.
That said, here is my question: I have a Frezzi Mini-Fill light (light bulb says: EXN 50w 12V) and I am wondering if there is any way to adapt the light so that I can plug it into a regular wall socket here in the United States?
Currently the light is not used because I don't have a way to power it and I really don't want to buy any portable batteries for the light.
I am betting the answer is no, but I thought I would ask to see if it can be done.
Thanks for letting me ask the dumb question...
Cheers, Jon
Jon Pavli is offline   Reply With Quote
Old January 21st, 2007, 04:13 PM   #2
Jon,
No you have a 50 watt, 12 volt lamp. Household power is 120 volt. I think that there are MR-16 bulbs that are 120V, but I don't know what they are. Look in the instructions, there may be a table of different lamps. EXN refers to the ANSI code for that lamp. That way you can find the same lamp made by a different manufaturer. Any EXN lamp, by any manufacturer, will be 50w and 12V and be an MR-16 type of bulb. Thay also have different beam angles, so some may be spot, or flood, or something in between. EXN is a 40 degree beam.
Most of these lights are made to run off a battery, so the connector may be a cigarette lighter, Anton Bauer power Tap, or four pin XLR conector. You'll want to be careful, because you don't want to accidentally plug something into the wall that's 12v and then fry it. That's why you may be better off sticking with battery power.
Mark Sasahara
Director of Photography
Mark Sasahara is offline   Reply With Quote
Old January 22nd, 2007, 03:37 PM   #3
Hi Mark,
Thanks for the answer. As I said, I thought 'no' would be the answer. You explained yourself well and I have learned a little more today. Cheers to you for taking the time to offer your thoughts!
Jon
Old January 22nd, 2007, 07:23 PM   #4
It's all about the love Jon, It's all about the love. :~)
Seriously, though, I'm happy to help. I've gotten help on the various boards, so I'm giving back. If you have any further questions, fell free to ask.
Mark Sasahara
