#46 |
I got my baking tin today and yes, it needs to be deeper, but in a pinch it works well. Also, maybe some ideas for creating light weight barn doors for this? I was thinking about cutting up some of the aluminum and using hinges, but I havne't tried it yet...
#47 | |
http://www.bealecorner.com/trv900/barn/barndoors.html H. |
#48 |
It won't work with baking tin because of the weight so another solution is probably necessary...
#49 | |
H. |
#50 |
It's funny, I never really thought of this as a softbox even though I guess it is!
#51 |
Well... it's a 'box' around a light, designed to soften it... so yeah, it's a DIY 'softbox'. Thats the properties I've been critiquing it on. Like I said, it's an elegant solution, especially for controlling spill... which is one of the bigger problems using worklights. That's why there are tutorials for building barndoors for them. This eliminates the usual barn door solution in favor of attaching a 'softbox'. Again, my primary concern for the softness, is the shallow depth of the pan. Aside from that, a cheap fix for low budget filmmaking.
Pro softboxes will have 'egg crate' grills that attach to the front, this helps to cut down on spill. Some have fabric 'barn doors' that velcro to the edges, but I've never really found those very usefull. A flag on a c - stand will do a better job. But if you've got flags, and c - stands... you're probably not doing this. |
#52 |
Where can you get those egg crate grills?
Also, I have noticed the baking tins are very flimsy (I only got the cheap $1.00 store one). Maybe the turkey ones are more rigid? Last edited by David Delaney; January 3rd, 2007 at 11:58 AM. |
#53 | |
Well yes they are only foil so obviously not going to be all that sturdy. Thats the joy of them. If they get smashed make a new one for a buck. I didnt get a chance to hunt for the deeper ones last night, but Ill look around soon. Have another shoot tonight, so see how it goes. |
#54 |
Hey Ryan, Just an Idea if you are really looking for some "depth" using the same kinda stuff.....They sell the cheap flat cookie sheets made of the same stuff(probably in the same Aisle at Walmart or Miejer)& you could get 4 of those and easily construct a traditional softbox shape and probably a pretty deep one. The joints could either be taped or just crimped(even pop-rivets if you please). Maybe I will try it too and see what I can come up with. Stuff like this is fun to me.
If you go to "cut" this stuff, be careful because it maybe sharp like an aluminum can. I still say your original idea is cheap, easy, portable & with great diffusion. Lets keep building on it. |
#55 |
Very helpful
I'm not a pro-am videographer. Just an indie musician trying to do some stuff on budget for simple apps.
That light diffuser tutorial was incredibly helpful. Thanks, Ryan. Best, Charles |
#56 | |
#57 |
Yes, I'll be doing most of the bs-ing...I know nothing about this stuff..Strictly amateur. Just trying to improvise ;-)
#58 |
Say, I am unencumbered by knowledge so I am going to throw out this possible suggestion for Ryan's work light solution.
Someone here mentioned that the distance from element to diffuser was too short. I don't know why that matters - but for now, I'm going to assume that it *does* matter. Assuming you build the softbox the way Ryan suggests (with EZ Foil Pans). Could you then not attach white foamcore pieces to the foil to effectively extend the "box"? Then attach the diffusion material? There is a foamcore softbox solution mentioned here: http://www.studiolighting.net/foam-c...emade-softbox/ If the foamcore doesn't actually touch the light element, would it still be in danger of melting? Thoughts, warnings? Charles |
#59 |
I've used the oil drip pans from the automotive isle at wallymart to build sheet metal boxes using a rivit gun.... then had them powder coated.... looks pretty good.... mind you, my project was with 24" daylight flo's.
#60 | |
