Arri D2 Kit - Page 2 at DVinfo.net
Photon Management
Old May 19th, 2003, 05:57 PM   #16
I have to second Ken's reaction to the Arri equip. I have the D2 kit too. Solid, professional gear & great light.
I don't have too much trouble getting everything back in the box. The trick is learning to re-coil the cables so the coils are the right size. Hold the coil in the left hand and the line between thumb, fore and index fingers of your right hand. Turn the cable about 1/4 turn with these fingers as you lay it into the coil (the line will "remember" its orginal coil). An old stage hand taught me this trick years ago and it almost never fails with cords or rope.
Tuck the switches into the center of the coils as you lay them against the side of the instrument in each of the cubby holes.
Peter Wiley is offline   Reply With Quote
Old May 19th, 2003, 09:20 PM   #17
Oh, I missed that Dylan was only joking, sounded like he really meant it, lol.
Akos Szemenyei is offline   Reply With Quote
Old May 19th, 2003, 10:14 PM   #18
<<<-- Originally posted by Brad Simmons :
You said "the Arri's are blue and silver. The Lowel's are black. Everyone knows pro gear is black."
So, if I get the Arri kit, and then paint the exteriors black, am I pro now?
Absolutely! ;)
Sorry you guys missed my (Humour) label at the top of my post.
Sadly, there probably is some truth to my joke in some circles... :)
Old May 19th, 2003, 11:15 PM   #19
Retired DV Info Net Almunus
Thanks for the cord coiling tips, Peter. I'll try that the next time I use the Arri's!
Old May 20th, 2003, 01:29 PM   #20
one last quesiton before I call up B&H today. (would have gone with the usual ZGC, but they were honest and said I would get a better price at B&H).
Ken and Peter, is there any reason why I should get the D2 instead of the D1 kit? The difference of course is the 150w and 300w in the D1 instead of two 300w in the D2. The price difference isn't that much at all, less than 100 I think. Do you think 2 300w would be a much better setup or is the 150w not worth it? Or do you guys wish you had a smaller 150w? I'm pretty new to this and I'm not sure if a 150w is really necessary or if 2 300w is overkill for my needs. I know this is a vague question but any advice would be appreciated.
Brad Simmons is offline   Reply With Quote
Old May 20th, 2003, 03:05 PM   #21
Brad,
That's an excellent question which I asked myself when I was making a selection. (BTW, the fixtures are rated only for the specified lamps, so you cannot use lower wattage lamps, at least to my knowledge.)
My conclusion was that the higher wattage set would ultimately be more flexible. You can always gel-down a higher-watt light but you can't produce more light from a lower wattage lamp.
Have fun!
Old May 21st, 2003, 03:36 AM   #22
thanks again Ken, I'll let you know how it turns out. I'm excited to get this kit.
