Dimmer on a fel lamp? at DVinfo.net
Photon Management
Old August 19th, 2006, 06:33 PM   #1
I am new to lighting and would like to know if
1) If you can use a dimmer with a fel lamp.
2) Will this significantly lower the life time of the lamp?
Jerrold Thompson is offline   Reply With Quote
Old August 20th, 2006, 10:11 AM   #2
Did a better search of the site, and the one response I found said there was not
a noticeable degradation of the life of the bulb.
Old August 20th, 2006, 02:06 PM   #3
That's true. If anything, dimming will increase the life of the lamp.
Seth Bloombaum is offline   Reply
