Suggestions on large-ish ringlights? at DVinfo.net
Photon Management
Old April 10th, 2006, 09:49 PM   #1
I'm curious if anyone has worked with any fairly large (i.e., 12" diameter or greater) ringlights and, if so, who made them... I haven't found many available, and what I have found (e.g., KinoFlo Kamio) tends to be fairly dim. I'm a bit surprised, frankly, that Kino didn't build the Kamio to hold more than one tube, just to boost the light output.
Scott Auerbach is offline   Reply With Quote
Old April 11th, 2006, 09:38 PM   #2
DVi Contributor
litepanel makes a very large ring light,LED. I believe you have to run it on a/c ?? the Kamio can run dc.
Craig Chartier is offline   Reply
