Mounting DIY lights on light stands at DVinfo.net
Photon Management
Old March 25th, 2006, 11:28 AM   #1
Chris Kenny
Posts: n/a
I think I've managed to find most of what I'd need to put together some low-cost fluorescent light banks, but the one thing I haven't been able to figure out is how to conveniently mount them on light stands. Ideally I'd like something like a screw pate attached to a bendable joint (with some tension, so it stays where it's put), with a standard 5/8" receptacle on the other end.
Does anyone sell such a thing? Alternatively, what other solutions are people using to mount DIY lights on stands?
Old March 25th, 2006, 11:57 AM   #2
Do a search on B&H on 'light stand adapter'. You find them for sub $10. Can you give us some more info about the lights you made? I'm very interested!
Vincent Rozenberg is offline   Reply With Quote
Old March 25th, 2006, 01:59 PM   #3
If you go to home depot or similar kind of place, look for three things:
-Circular panel cover for outdoor security light. You know those motion lights with two lamps plus motion sensor? You want to find just the plate that has three 1/2" threaded holes and four screw holes.
-Copper pipe 1/2" gauge sleeve-to-thread adapter.
-Copper pipe 1/2" gauge, 8'' long end pipe. This will have an open and and a "bullet tipped" end.
Solder the end pipe to the thread adapter. Thread the pipe into the plate. The copper pipe is the same gauge as a C-stand extension arm and thus can be mounted onto a gobo head. The pipe can be detached for unobstructed storage.
This may seem like a mouthful, but it is very simple. I've done this for many of my own custom flo lights and it works very well. It's much more simple than trying to fabricate a yoke or some kind of articulated pin adapter.
Matt Irwin
DP / matt.irwincine.com
Matt Irwin is offline   Reply With Quote
Old March 26th, 2006, 12:12 AM   #4
Chimera Lighting
I don't know what you got but
I would look at www.bogenphoto.com
under avenger grip
Matthews is good to
American as well
look on line.. catalogs can be better
peace our
rv
Strength and Honor
RLV
Richard Veil is offline   Reply
