Lighting on a budget at DVinfo.net
Photon Management
Old March 13th, 2006, 02:00 PM   #1
Hi all, this is my first post so please go easy on me.....
This might sound a stupid question but here it goes. I have seen in my local builders store sets of 500 watt halogen lamps on stands fully adjustable for lighting outside for building sites (£19.99), and i have also found a shop that sells spair bulbs so i can choose the correct colour temperature accordingly, so theoreticly this would make a cheap indoor light right? maybe im wrong but it seems ok
any views?
Chris Bottrell
Director R18 Wholesale LTD
Canon XL2
Chris Bottrell is offline   Reply With Quote
Old March 13th, 2006, 03:27 PM   #2
What are you going to use them for?
Emre Safak is offline   Reply With Quote
Old March 13th, 2006, 05:02 PM   #3
Images: 32
Worklights are great to brighten up a location, but the light can be difficult to control. For more ideas, check out the Low Budget Lighting Article by Scott Spears.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline   Reply With Quote
Old March 15th, 2006, 11:15 AM   #4
Part 2?
Hey that was a very interesting article. At the end he wrote "there will be more in part 2" Can you do me a favor and post a link to "part 2"?
Matt Ymbras is offline   Reply With Quote
Old March 15th, 2006, 02:19 PM   #5
Images: 32
That link has both parts 1 & 2 in it. You can also check out Scott's online tutorials.
Old March 16th, 2006, 04:24 AM   #6
"and i have also found a shop that sells spair bulbs so i can choose the correct colour temperature accordingly,"
Halogen lights are a type of tungsten light. They are all in the neighborhood of 3000K and won't match daylight without some serious blue filtering (full CTB). This cuts down the amount of light by at least half and you are already fighting the sun in a daylight scenario. The amount of light needed in daylight (even through a window) can get you into a situation where you are kicking circuit breakers with tungsten. Renting HMI lights for big shots, or fluorescents for smaller locations is a better solution. You can also build your own daylight-balanced fluorescents that can be fairly bright without overloading circuits.
Marcus Marchesseault is offline   Reply
