How to light a medical clinic at DVinfo.net
Photon Management
Old May 9th, 2016, 09:01 AM   #1
I'm having to shoot a Q and A video in a clinic/lab and trying to figure out how best to light it. I don't have a lighting kit so I'll have to buy one (actually, the clinic will). I'm trying to find the most efficient best value option.
I'm thinking getting some high CRI fluorescent bulbs (5500k) to replace the ones in the ceiling near the shooting area. Not sure what to do from there. What would you guys recommend?
Jonathan Grant is offline   Reply With Quote
Old May 9th, 2016, 11:43 AM   #2
Re: How to light a medical clinic
Read through any of the "what should my first light kit be" threads in this forum. The opinions are varied. I'd need to know more about what you're shooting, your skill level, and your budget to give particular recommendations.
In general, look for soft key light (LED panel, fluorescent) and a hard back light (fresnel). A third light will help you illuminate the background.
Mike Watson is offline   Reply With Quote
Old May 9th, 2016, 05:03 PM   #3
The most important questions are how many people and how much area do you need to light?
For instance, if it's a two person Q&A, that's one thing. If it's a five person panel in front of a 100 person audience, that's another.
For the large audience, high CRI tubes make a lot of sense. I regularly film a corporate meeting and just use the built-in lighting (LED tubes) for the audience. For the speaker, I use two stage ellipsoidal lights, one as a key and the other as a backlight. Sometimes, I gel the backlight with a 1/4 or 1/2 CTB to give a slight blue cast. Those lights work well as they are tight spots that I can move far from the lectern. They've got "slats" (or whatever one calls them - like barn doors, but they slide in and out) to block unwanted rays.
In my case, the lectern is also under the general lighting, but it's between bulbs, so the speaker's face is relatively dark without additional lighting. Lighting the speaker transforms the feeling of the result from "amateur" to "(semi)pro".
Regarding the background, it depends. Is it plain, busy, dark, or light? Often, leaving the background a bit dim is nice for getting the subject to stand out. If the background is busy, it's nice if there is distance so you can blur it with shallow DOF. If it's plain, one trick is to use a wrinkled, colored gel or foil on the floor and to bounce a strong spot off of that. It will reflect a mottled pattern that makes a blank, white wall look interesting. :)
Jon Fairhurst
Old May 12th, 2016, 11:37 AM   #4
Johnathan,
Here is one of the type of old threads Mike is referring to:
http://www.dvinfo.net/forum/photon-m...-old-ones.html
There are shots there from a time when I lit a medical clinic but it sounds to me like all the general lighting discussion will be more important to you. Lighting a Q&A session is different than lighting medical procedures. We need more details on what your doing?
Kind Regards,
Steve
www.CorporateShow.com
Steven Digges is offline   Reply
