Lowel Pro Light scrims cast screendoor shadows at DVinfo.net
Photon Management
Old August 3rd, 2013, 12:11 AM   #1
I bought Lowel Full and Graduated scrims for use with my pro lights (in the swing-in accessory holder that clips on to the barndoor frame). The scrims seem basically useless because the small light bulb of the pro light acts as a point source and casts a screendoor pattern on whatever is being lit.
Is there something I'm missing? Anyone use these Pro light scrims successfully? I suppose I could add lots of diffusion but that defeats the point of the scrim which is to be able to adjust light output without going to the trouble of dealing with gels.
Tom Morrow is offline   Reply With Quote
Old August 3rd, 2013, 11:31 AM   #2
Re: Lowel Pro Light scrims cast screendoor shadows
Hey Tom,
You must have tried this but I will bring it up any way. There is only one adjustment on Pro Lights. Did you turn the dial on the side to the "wide" setting?
Steve
www.CorporateShow.com
Old August 3rd, 2013, 11:17 PM   #3
Do you have the "prism" glass in place? This usually comes with the unit and diffuses the light just enough to give a single "almost sharp" shadow. The scrims should work properly (simply cutting light output) this way.
Ken
Ken Plotin is offline   Reply With Quote
Old August 4th, 2013, 12:12 PM   #4
Yep, I always use either the prism or frosted glass or external diffusion with the scrim, otherwise it's exactly as you say
www.mcbob.tv
Kevin McRoberts is offline   Reply
