How was this interview lit?
I'm very impressed with the lighting from the interview segments in this video, it almost looks like it was lit with one light? At first guess I'm thinking a very large soft box, with some obvious background lighting.
I'm not seeing any hair light, and possibly only minimal lighting for fill? I was hoping someone could take a look and guess how this was lit, as I'd like to do something similar. If you skip around in the video there are a bunch of different interviews, all in the same location. Thanks, |
Re: How was this interview lit?
Yep, looks like a fairly large and soft single source from the front; with almost certainly some blacks used for negative fill on the sides. Then the background's either been lit with practicals, or some additional lights have been rigged up to add interest.
Mark, by "blacks" are you referring to possibly some black flags on the sides to create that dramatic shadow on their face?
Yep, either black flags or styrofoam panels would be my guess.
#5 |
+1 but English narration with english subtitles is disturbing over 30 minutes, and they start getting out of sync from 24.36.
Think twice before you do that, they're only for the hearing impared but they take away from the vision, which is great in that program btw. Maybe there's an on/off subtitles button in the menu. Cheers.
Support your local movie theatre, they need it. |
#6 |
Yeah, not sure about that. The only thing i'm looking at is the lighting of the interviews.
#7 |
The eyes and hair usually tell you everything you need to know about the shape, position and intensity of the light sources.
#8 | |
I usually take as my clues the modeling and shadow caused by nose and jaw. This will also indicate the hardness of the source, which is another important factor. A large hard source may read the same in reflection as a large soft source of the same shape, but it will have quite a different effect.
Charles Papert www.charlespapert.com |
#9 |
Look at the eyes at 1:11 - I see 3 lights.
#10 |
This piece was directed by Erroll Morris, who uses the interrotron, so one of those spots in his eye might be the teleprompter screen.
The guy at 8:02 has a very odd look, the front of his face is lit up, but the sides of his face are dark. How do you "bounce" black back onto them? This is the part that I'm baffled by. |
#11 | |
#12 |
That source is dead center, not off to the left, as can be evidenced by the shadow under the nose and chin which is perfectly centered.
Without knowing anything about the space, it's hard to say if solids were required to create the negative fill on the sides of the face. I'm sensing an impression here that doing so will "reflect black" into a face--that's not the case. It's simply the absence of light. If there is no ambient light coming from anywhere but the front source in the room, the solids won't do anything extra. Likewise, without knowing what the background actually is, it's impossible to tell how it was lit.
#13 |
Can you focus soft light? I've seen the lowel pro lights, the dedolights, etc, that can be focused, but those are rather harsh sources. Even using an egg crate I do not believe it would be that directional
#14 | |
#15 |
Not sure which side is which--I would say his right side (which appears on the left side of the frame is less lit than his left. To me it looks like natural bounce back from the background, creating a very slight and soft edge on his left side.
Regarding Paul's comment--while soft light doesn't focus per se, it can be controlled in the fashion that one may associated with focus. An extended egg crate designed for narrow throw will tighten the spread of a soft light to a considerable degree.
