Shooting under black lights at DVinfo.net
Photon Management
Old March 31st, 2012, 01:34 PM   #1
Our church as a puppet team that preforms with black lights. The video looks terrible. How can I set up my Canon GL2 where it will video in this enviroment? Shound I buy any extra equipment?
Barry Edmundson is offline   Reply With Quote
Old March 31st, 2012, 04:50 PM   #2
Re: Shooting under black lights
Consider that if they're the old tube-style black lights, they're probably flickering on and off 120 times a second. You're probably locked to shooting at 1/60th of a sec shutter speed -- anything else will give a noticeable flickering or strobing as the camera shutter moves in and out of phase with the flicker.
You said the video "looks terrible." HOW does it look terrible? We need to know the symptoms before we can suggest a cure.
IF it's the shutter-speed issue I suggested, staying at some multiple of 1/30th of a second should take care of the issue. If that isn't possible, then I'd suggest either converting the blacklight fixtures to a solid-state ballast ( which USUALLY runs at a higher frequency "flicker" rate than the old magnetic ballasts), or try converting to the compact florescent blacklight corkscrew bulbs.
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old April 1st, 2012, 01:47 AM   #3
Black lighting eh, is it necessary for the show?
Wonder how the audiences like that, maybe suggest a performance for just for you with 'normal' lighting. You could try 'blackening it' in post,
but work on that effect first.
Cheers.
Drink more tap water. On admission at Sydney hospitals more than 5% of day patients are de-hydrated.
