lighting challenge at DVinfo.net
Photon Management
Old March 29th, 2012, 11:29 AM   #1
lighting challenge
I know how to set up standard 3-point lighting for an interview (showing only the subject, not me), but I've never faced this set of challenges before.
Small office, about 10 ft deep and 8 ft wide.
No windows.
One ceiling fixture, about 5ft x 2 ft, casting a dim yellow (to casual observation) light. I would turn this off.
Only way to shoot is for him to be sitting at one end of the long dimension and camera to be opposite.
I have two Kino Flo 200 lights with daylight fluo, and 2 reflectors with daylight CFL bulbs.
The subject is an African man with very dark skin.
So basically, a small, pitch-black room and a very short time to shoot.
Question is, do I need to modify the usual setup to accommodate all these conditions?
Philip Fass is offline   Reply With Quote
Old March 29th, 2012, 01:00 PM   #2
Re: lighting challenge
Try to shoot into the corner, vs. facing a wall flat on. Bring your key/fill lights close to subject (not that you have much choice). This will give you a soft/flattering light. The rest depends on what 'look' you're going for. If you want some drama, use grids to keep the spill off the back walls. If you have a cookie and spotlight, you can add some interest to the back corner.
Shooting large sensor with fast lens will help keep the background out of focus.
Oren Arieli is offline   Reply
