question for Zylight Z90 owners at DVinfo.net
Photon Management
Old January 27th, 2012, 10:25 AM   #1
Have you ever found that noise from the Z90's heat sinks and fan is a problem when you shoot?
I've seen it described as everything from barely audible if you have your ear next to the light, to a deal killerf.
I don't live anywhere near a dealer, so I can't try it myself.
Thanks.
Philip Fass is offline   Reply With Quote
Old January 28th, 2012, 02:12 PM   #2
Re: question for Zylight Z90 owners
I have two Zylight Z90 that I've been using for over two years and didn't even know that there's a fan inside.
NinoMedia Productions - EFPLighting.com Advanced Lighting and Gripping Workshops
Nino Giannotti is offline   Reply With Quote
Old January 31st, 2012, 12:12 AM   #3
I am fairly sure there is no fan in a Z90.
What people have complained about is more of a high pitched tone that shifts when you dim the light. I haven't had issues with it myself in terms of it disrupting audio.
Charles Papert
www.charlespapert.com
Old January 31st, 2012, 07:18 PM   #4
No Fan, no noise. There is a slight green shift that you have to dial out when you dim the light.
Bob Willis is offline   Reply With Quote
Old February 1st, 2012, 08:10 AM   #5
Thanks, all. Very reassuring info.
Old February 7th, 2012, 10:23 AM   #6
Here's another question: There are lots of small, universal soft boxes made for flash photography. This is an example:
http://www.bhphotovideo.com/c/product/62832-REG/Westcott_2200_Micro_Apollo_Softbox.html
Is there any reason something like this wouldn't work as a less expensive alternative to the Zylight/Chimera soft box?
Old February 12th, 2012, 03:47 PM   #7
The Z90 does generate some heat so I don't know how well a diffuser designed for flash will work with the heat of continuous light. If you have adequate insurance, try it.
Ned Soltz
Ned Soltz is offline   Reply With Quote
Old February 12th, 2012, 04:23 PM   #8
If you're looking to soften and spread the source a bit try some Tuff Spun. I use it on all kinds of lights including Lowell DPs as well as my AB Ultralite, a 100W Bescor (AC Powered) and my LP Micro.
Don
Old February 12th, 2012, 05:24 PM   #9
Don, what would you use to attach the Tough Spun to the light?
Old February 12th, 2012, 07:45 PM   #10
There is a barndoor accessory available for the Z90, which is probably the best way to attach diffusion to the unit.
Gotta say though--tough spun is pretty darn old school, Don!! I haven't seen it on set for many, many years (granted it was the go-to when I first started lighting back in the 80's). The percentage of transmission vs the diffusion effect is really not very efficient compared to, say, 216. Given the tiny footprint of the Z90's emitters and it's fairly low output, I would be inclined to say that spreading the barndoors to an approximate 45 degree position and diffusing with 250 would give you as much transmission as possible with a decent sized source.
If transmission isn't an issue (with DP lights and today's sensitive cameras, probably not), tough spun isn't a bad choice--it's durable and silent in the wind.
It's just a nostalgic concept! Thinking back to the Smith-Victor lights that came in a cardboard travel box, and tough spun clipped to those collapsible Lowel gel frames in front of Totas and Omnis--remember the big Lowel softlights with the silver-coated reflector bags that you slid over the hinged frame? Haven't seen one of those in a very long time, wonder if anyone is still using them!
I actually used the original Lowel Lights (later called the K5, now the L-light) for a tricky setup in a living room that required ceiling mounted hard lights for a period look with quick rigging. We gaff-taped the plates to the ceiling and used halogen screw in bulbs. Worked great. It's in this week's "Key & Peele", I'll post a link if Comedy Central releases that sketch online.
Anyway--back to the Z90; just used that and the Zylight IS3 on a recent spoof of "The Bachelor". I had a set of RGB LED theatrical units to create the super-saturated splashes of color they like to use around the mansion on that show and the Zylights were great to augment those colors as needed--really easy to dial in to match the hues of the theatrical washes.
Charles Papert
Old February 12th, 2012, 08:57 PM   #11
Philip,
Gaff tape is my friend!
Charles,
Yeah Old school is right..Especially when you've got 2 extra sheets of 24X24 sitting in the supply closet and you can't kill the stuff. Yeah, it isn't great for the small lights. Actually I've got some vellium material that I "borrowed" from my wifes craft closet that works really well as diffusion material and isn't as big a drop off in effective output as the tough spun.
I always say necessity is the mother of invention and we use what we got. Hell, once a long time ago, I used a coffee filter (unused) although I know a guy that used a used one and he loved the nice warm color the light threw. What can I tell you.
0|0
Don
Old February 12th, 2012, 11:28 PM   #12
am still a fan of spun, i always carry a roll of light, medium and heavy in the van.
i still have hot lights in my kit so i find it invaluable.
although if i am using frames i go with half or full white diff.
for led's i would use quarter or half white diff, pegged or gaffed to the barn doors.
cheers
Ian Dart is offline   Reply With Quote
Old February 13th, 2012, 11:24 AM   #13
What about parchment paper? Not the historic kind, but the stuff used in baking. Definitely heat resistant.
Old February 13th, 2012, 12:34 PM   #14
Ian, no reason you can't use the white diffusions right on barndoors--sounds like you are suggesting there is a heat issue that tough spun is better suited for?
re: parchment paper etc. The type of diffusion we are talking about is $6 for a 2x2 sheet--not exactly a bank-breaker, and you can use it on all types of lights.
Charles Papert
Old February 13th, 2012, 03:31 PM   #15
hi charles,
my biggest incandescents are 2k blondies and if i have no room for frames
i use spun on them as white diff tends to turn a nice shade of "pharaoh sand"
spun is also handy for using on windows, easy to hang and is quiet if windy.
it is also handy if you need the light a little harder.
cheers mate,
