Do ND gels have slight tints to them? at DVinfo.net
Photon Management
Old August 31st, 2005, 02:58 PM   #1
1- Try this:
Take two objects that look white to you. Put them side to side. Are the two objects exactly the same color? (i.e. no color tint to either object)
From what I've read, most objects aren't truly white as they don't reflect all wavelengths 100% (or in equal proportions).
You'd probably find something similar with grey objects.
Which means ND gels probably add a slight tint to light passing through up. I'm wondering if anyone has ND gels that they can perform a test on them?
2- On a internet site somewhere, I saw a comparison between Harrison & Harrison filters (for cameras) versus other brands and there's color tints to the other brands. This probably doesn't matter for a camera filter. I can't seem to find it though.
3- I'm guessing the slight tint added by ND gels are too neglible to make a difference.
I might test this out, although I don't have a reasonably sized ND filter or real lights.
Old August 31st, 2005, 08:36 PM   #2
ND gels tend to have a very slight magenta tint--it's not that noticeable usually, but if you stack them up deep on a window you might find the exterior looking a tad purple.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
