Softening IR Light? at DVinfo.net
Photon Management
Old January 13th, 2011, 09:22 AM   #1
Images: 5
Softening IR Light?
So I've got a baby on the way & being the video geek I am, I haven't been satisfied with the quality of my baby monitor's video in pitch black & figured I need to add a secondary IR light source to improve it.
Problem is, all the cheap IR light sources I find are fairly narrowly focused. Usually I'd solve something like this by adding a diffuser of some type but knowing nothing about IR can you soften an IR source? If so, what type of material would work?
I figure other than for my odd little application this type of info could be useful to many people using IR sources for more professional purposes.
-Ethan Cooper
Ethan Cooper is offline   Reply With Quote
Old January 22nd, 2011, 10:54 PM   #2
Light's light. Put a piece of glass or plastic in front of the LED's and spray it with hairspray until you get the right amount of diffusion. If the LED's are around the lens, put a round piece of tape on the glass where the lens peeks through, spray the glass, then peel the tape away so the lens has a clear spot to look through. The nice thing about hairspray is you can clean it off and try again if you put on too much, plus your wife probably has a can or two already.
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old January 23rd, 2011, 11:06 AM   #3
Images: 5
I had just figured the wavelength of IR light might interact differently with traditional diffusion material. If it doesn't then great, good to know.
-Ethan Cooper
Old January 23rd, 2011, 05:18 PM   #4
It --might--. Some plastics that are opaque to visible light will pass IR, as anyone who ever developed IR-sensitive film in a plastic developing tank can attest (stainless steel ONLY). The converse is also true, as a silicon slab is opaque to visible light, but passes IR like, well, glass.
Play around -- hair spray, waxed paper, vaseline. See what works.
Martin
Old January 24th, 2011, 06:24 AM   #5
I don't know how widely available they are but down here you can find IR LED kits pretty cheaply that seem very simple to assemble. As you're mounting the LEDs yourself it would be easy enough to leave the leads a little longer and angle the LEDs to give a wider beam.
Bob Grant is offline   Reply
