Chimera Video Pro Plus Softbox - Large - 54x72" (135x180cm)
Hello
I'm considering the Chimera Video Pro Plus Softbox - Large - 54x72" (135x180cm) , I wonder which speed ring would I need to attach to redhead light ? |
A Redhead will not have sufficient output for a large Chimera. I use my open faced arri 1k with my Medium Chimera and it barely has enough output for most situations. I use my Mighty Mole (2K) with the medium and it can fill up a large, almost, perhaps in a dark room or set.
The other factor with a large Chimera is that few lights under a 2k or 4k have a strong enough yoke to hold up a softbox with that kind of weight so you end up mounting the speed ring and Chimera to a separate stand from the light, making the whole setup rather ungainly to move. Dan |
I see , one redhead is 800w . here is my lighting stuff :-
- 2400W Red head Studio Light Kit Dichroic Filter Dimmer ( 3 lights ) - Lowel PRO-LIGHT wish snoot (For rim ) - FLO CL-655PMD Cool Lights Portable Dimming 6 x 55 watt Softlight , CL-255PMD Cool Lights Portable Dimming 2 x 55 watt Softlight all with eggcrates . |
Laffan:
For a Redhead, you be best off with a Small Chimera. You need something with more power even for a Medium, much less a Large. Larges are most commonly seen with something like a Barger Bag Lite or a at least a 2K and up type of light. Best, Dan |
#5 |
Thanks Dan , Which speed ring would I need for the redhead ?
#6 |
Probably this http://www.bhphotovideo.com/c/product/13631-REG/Chimera_9560_Speed_Ring_for_Video.html
Dan |
