lighting a two person dialogue scene on a budget? at DVinfo.net
Photon Management
Old September 27th, 2010, 08:26 AM   #1
I was wondering how to light a standard two person dialogue scene.
The setting will either be my house or my friend's apartment. I will be shooting on a Canon EOS 7D, which i know works well in low light situations.
The question is, for additional lighting, what should I use if i have next to no budget. I do have an option to check out some lighting equipment from my college though,
any ideas?
Lee Tamer is offline   Reply With Quote
Old September 27th, 2010, 09:40 AM   #2
Are you shooting singe camera? You have zero lights, grip and electric and zero budget? You had better find a location that has some good available light. Not to say that you can't end up with a nice looking scene without lighting it, but it is much more difficult. Soft diffused window light will be your friend.
If had a good budget, I would probably still try to emulate window light, it is the most motivated source in most rooms, especially if you ever will see windows.
Dan
Old September 27th, 2010, 11:17 AM   #3
I'm hoping to get my hands on a second 7D, but if I cant, it'll be single camera.
I was thinking of using maybe a simple china lantern above the two actors heads. I'm not sure what else i'll be able to get,
Like i said i'll be able to check out equipment from school, i'm just not sure how much
Old September 27th, 2010, 11:33 AM   #4
I sometimes use a single Smith-Victor with 10" reflector and a bright white 100W equivalent CFL bulb and "redirect" it for each actor. If the actors are good I'll have them deliver all their lines, breaking it up a bit for camera repositioning, then switch the light position and direction for the other.
The other approach I use is to reposition light and camera for each actor as their "turn" comes up. That's the way I worked this one:
It keeps you busy but it works.
Old September 27th, 2010, 12:23 PM   #5
If you are going to shoot two camera, I like your idea of a China Ball. I shot project about 3 weeks ago, four people at a table, six camera shoot like a poker game. My key light was a 30" China Ball with a 650 watt tungsten EGW bulb. You can get the entire setup at FilmTools for around $50.00. It works great except that you have to build a skirt around it so the soft light doesn't go everywhere, making your scene look too flat.
We used Duvetine to make the skirt but we needed a lot of C-stand arms and Mafer clamps, if you have no budget, not sure how you will control the light without grip tools.
Dan
Dan Brockett is offline   Reply
