Powering a on camera light with AC
I have a NRG on camera light and I want to use it to light interviews but I don't want to haul the 12 lb battery with me. Is it possible to bridge the AC Battery charger to the light without the battery. Basically I need a power cable with cigarette (female) connector on both ends.
NRG | 56001 Varalux Pro DC Dimmer On Camera Light | 56001 | B&H Only thing I can come up with is buy two of these cables, cutting them in half and splicing the two female end together http://www.bhphotovideo.com/bnh/cont...u=92992&is=REG |
The specs at B&H say this is a 100 watt light; I'm guessing your battery charger doesn't put out 100 watts, it wouldn't need to do that just to charge the battery. I don't think it's an ac power supply, which is what you would need...you could check the specs on the charger itself... iirc, 100 watts at 12 volts is a little over 8 amps.../Battle Vaughan
it doesn't appear this light is compatible with AC. I have an old Bescor that can be useed with AC by 1) changing to a 100W bulb and 2) pulling the cig adapter off the end of the cable from the light since it already has a 2 prong plug on it. I have used it in the same way you are talking about. It sure keeps the weight of that battery belt in the car.
If you're going to be on a tripod why not wrap the battery belt around the tripod legs and then run the light. No weight on you and you don't have to worry about AC cords. Of course you do have to watch your run time so you don't run out of battery power.
What do I know? I'm just a video-O-grafer. Don |
#4 | |
#5 |
To power this light you'd need a 12V 10amp transformer, the lamp will be just as happy running off AC or DC. Such things are available and would be a safer solution than changing the lamp for a 110V one and running 110V AC to the lamp. Also a 100W 12V lamp produces a bit more light than a 100W 110V lamp and is more robust because of the thicker filament.
#6 |
Powering a dc bulb is not the same as ac. The amperage differs by about 10x's. Example: a 100 watt dc bulb needs about 8.3 amps whether you use a battery or a transformer that puts out dc. A 10amp transformer rivals the weight of your 12 lb battery.
A 100 watt ac bulb needs .83 amps at 120 volts ac. Unfortunately there is no benefit to what you want to do. That cigarette lighter extension can only handle a couple of amps, it will get very hot and start smoking almost immediately. By the way, why do you want to use an on camera light for an interview? That type of lighting will look horrible. Gary |
#7 |
I'm glad you guys warned me. I did deposition where the camera was wide open and at 6db gain. I was going to bounce my camera light off the ceiling to increase the exposure a couple of stops so I wouldn't have to use any gain. I could have brought 9" clamp light you find at the hardware store, but they're cumbersome, delicate to pack, don't mount securely, and don't look as professional.
#8 | |
A 12V 100w light bulb will use exactly the same amount of current running off 12V AC as it will running of 12V DC. In both cases the current = 100 div 12 = 8.33 Amps. Assuming the light with it's cigarette lighter plug can happily run from a 12V battery it'll run just as happily from a 12V AC transformer. Those cigarette lighter plugs and sockets come with a fuse. All the ones that I've bought have a 10 amp fuse in them. The cigarette lighter in a car draws around 10 amps. We've run lots of gear from the lighter sockets in vehicles. The wire in that extension lead does look a bit thin for 10A though. [edit] A horrible thought entered my head after posting this. This light uses a dimmer and is speced at 12V DC, the lamp will not care if it's DC or AC but the dimmer very likely might. Anyways I found you a 12V 10Amp DC power supply that'll work as a battery replacement here: OFNA 12V/10A Regulated DC Power Supply [OFN92135] Sorry about the confusion Last edited by Bob Grant; October 1st, 2009 at 08:40 PM. Reason: Additional information |
#9 | |
#10 | |
There's also at least one vendor selling suitable switch mode power supplies on eBay To be honest though if you intend to stick with using an on camera light it might be time to consider an LED or HID light. They're way more efficient than a tungsten light so they need less power and produce less heat. They're also lighter. |
#11 |
Bob Bob. If you look closely I didn't mention using anything about diodes to covert the voltage to dc. As you must agree it doesn't matter whether it's ac or dc the amperage is the problem. An 8.3 transformer (before conversion or not to dc) weighs a ton which is the reason why Pete wanted to convert it to ac. He didn't want to carry around a heavy battery.
I have used a newer version of converters for my high amperage LEDS which are made for car coolers, etc., they use electronic transformers. The problem is that I haven't seen anything above 6 amps. Gary |
#12 | |
#13 |
I'm not if your post was to me, but I have the 6amp converters with cigarette light plugs on them already. My maximum demand for the crees is 4 amps.
Gary |
