Light stand recommendations for Parabeam 200
Hi all,
I'm looking for light stands for the Kino Flo Parabeam 200s. Build quality, stability, and portability are important. Any recommendations? Thanks, Mel
Mel Williams |
Hi Mel, the 200s use baby-stud type stands (400s use junior-types) so here are a couple heavy duty baby stands that can support 17lbs, made by MSE and Avenger:
B387490 - Heavy Triple Riser -- Black http://www.msegrip.com/mse.php?show=...ducts_ID=25019 Weight: 7lbs Load Capacity: 25lbs A410B HIGH ALU-BABY WITH LAZY LEG http://www.bogenimaging.us/product/t...150&itemid=419 Weight 8.9 lbs Maximum Load Capacity 22.1 lbs Addressing your concern for portability and weight, I didn't include C-stands made by either company, since they have the same weight capacity but weigh twice as much. As a matter of caution, I would always use sandbags on any stand carrying a non-centered instrument like the Parabeam. I am a dealer for both these manufacturers, and can get any product they make.
Want to get more from your hard-earned gear? Digital Cinema Filmmaking Course 24 hours of educational video on 16 DVDs, focused on filmmaking savvy, examples, demonstrations, and tips. Learn Scriptwriting, Formatting, Editing, Camera Operation, Lighting, Exposure, Audio, and Directing. |
A stand's weight rating will be a good measure of how stable it is. I've got a local shop that has ParaBeams mounted on Matthew's C-Stands... and they're solid as a mutterfutter.
I like Manfrotto's model 3398B... and also the 8' "stacker" stands. You gotta' get the 8' version OR higher to get more solid legs. (The Manfrotto stands get exponentially more solid as the price and weight ratings go up... the 8' stackers are the minimum I'd use... the starting point.) First decide what minimum/maximum height you want and then browse the B&H pages and see what you find... it won't be hard to find several great choices... and it's the most fun way I can think of to spend a couple hundred bucks... strip clubs aside. |
Ditto what Rush said, be sure to bag the stands. Beefy Baby Double, or Triple Risers, or C-Stands would also be good. Matthews, American, Avenger, Norms, Modern Studio Equipment. To give yourself a little flexibility, try using an offset arm, 20 inch gobo arm, or a right angle baby pin. You can mount the yoke horizontally and be able to tilt the Parabeam at any angle. Be sure that the light is directly over one leg. The Parabeam is meant to be hung from a grid.
Mark Sasahara Director of Photography |
#5 |
Thanks everyone...
...you guys are great!!!
Mel
Mel Williams |
