Lighting for DV question at DVinfo.net
Photon Management
Old February 11th, 2005, 06:30 PM   #1
I am having trouble finding information about how different types of light affect your Digital Videos. I am looking for the correct shutter speeds to match to the type of light source.
Any help or suggestions would be helpful.
Thank you
Thanks for your help everyone.
Thomas Fraser is offline   Reply With Quote
Old February 11th, 2005, 10:26 PM   #2
What type of lighting are you thinking about?
Offhand I can't think of any that require SHUTTER speed changes.Although flourescents may be affected by specific shutter speeds
Typically the type of light affects the "look " eg. Kinos are softer than Tungsten etc.
Jack Smith is offline   Reply With Quote
Old February 11th, 2005, 11:34 PM   #3
Light affect
It was in fact a set of flourescents, which , as I now find out had an old balast, which caused the video to have a strobe or flicker like affect. I deinterlaced the video in Premiere Pro and it looks much better now.
I am new to lighting , is there diffrent rules and techiques for lighting video then lighting film?
I had been told that shutter speed was a factor.
I have a lot to learn on this subject.
Old February 12th, 2005, 04:06 AM   #4
Re: Light affect
<<<-- Originally posted by Thomas Fraser : It was in fact a set of flourescents, which , as I now find out had an old balast, which caused the video to have a strobe or flicker like affect. I deinterlaced the video in Premiere Pro and it looks much better now.
I have a lot to learn on this subject. -->>>
Yes, you have to be careful what fluorescents you are using with what shutter.
As a general rule they have to be the same: when in 50Hz countries use 1/50 shutter, when in 60Hz countries go for 1/60 shutter. Other shutter options may cause flickering, and you would need a good location monitor to see them.
Better yet is to use flickerless fluorescentes, like those new fluo bulb replacements that became so popular. They allow you to use any shutter position and do fine.
Carlos
Carlos E. Martinez is offline   Reply
