Black light at DVinfo.net
Photon Management
Old December 18th, 2004, 10:24 PM   #1
Black light
I'm shooting a Christmas play that is employing the use of black lights. When I am filming, the lights give off a green neon glow! I am using 2 GL1s. How can I adjust the camera to get rid of that green glow?
Gabrielle Talley is offline   Reply With Quote
Old December 19th, 2004, 06:47 AM   #2
I've never tried to use black lights, but the first thing that comes to mind would be to white balance to a normal flourescent lamp before using the black light. That should take care of the green.
Tony
"Good taste is the enemy of creativity" - Picasso
Blog: http://www.tonyhall.name
Tony Hall is offline   Reply With Quote
Old December 19th, 2004, 01:06 PM   #3
I white balanced to a white t-shirt, but I'll try white balancing to a light. Maybe it'll work. If not, I'll just keep the area that is showing green off of the screen. Thanks!
Old December 19th, 2004, 02:34 PM   #4
Black light is UV light which is not seen by CCD camcorders only the "glow" (fluorescence) on some objects (shirts...) shows in the visible spectrum and is almost monochromatic. So this cannot be "white balanced", unless you go for B&W pics.
Andre De Clercq is offline   Reply With Quote
Old December 20th, 2004, 06:57 PM   #5
Would a UV filter take care of the neon green glow problem that the camcorders were picking up?
Old December 21st, 2004, 04:07 AM   #6
No Gabrielle, the UV light is being converted into green light. So the light that the cam ''sees'' is real green.
