Quick Halogen Question... at DVinfo.net
Photon Management
Old November 17th, 2001, 04:17 PM   #1
Just curious, are most of the run-of-the-mill Halogen globes you can buy at home depot or similar store all rated at around 3200k?
Casey Visco is offline   Reply With Quote
Old November 19th, 2001, 07:57 PM   #2
nevermind!
sorry for wasting the space, i figured that one out on my own
Old December 17th, 2001, 06:22 PM   #3
The Blonde
Posts: n/a
I had the same question a while back so I rang a manufacturer, (Philips in this case.) 2900K was the reply.
A sheet of 1/4 CTB gel brings them up to 3200 nicely.
I made my own stands and barn doors for the lights,(painted them all black with BBQ paint so they look good) & voila! (or some other French word), a VERY cheap, effective, portable lighting kit!
Andrew.
Old December 17th, 2001, 07:07 PM   #4
i gel mine with a 1/8 ctb generally...i did find most halogens to fall around 2900 or 3000...
and nothing beats do it yourself lights! I mentioned in another post i think that to supplement my regular kit i bought a few clamp-lamps, and tossed some halogen pars in them.
i broke out AutoCad and designed some removable accesories, each with a mount on the back that attaches around the lip of the reflector of the fixture. So out of thin metal I made some filter trays, (in which go the ctbs), barn doors, and also the afore-mentioned softbox faced with 216.
and if anyone else has any other crafty ideas, do post them! =)
c
Old December 28th, 2001, 12:19 PM   #5
vuduproman
Posts: n/a
Process Explanation
Could you explain the whole process from start to finish and approx. how much you paid for your do it yourself lights? I'd really like to know as I am considering to do the same due to low budget.
Old December 28th, 2001, 11:35 PM   #6
This is what I did
I followed the step by step instructions here:
http://www.dv.com/magazine/2001/0401/bjohnson0401.html
It costs between $150 and $200. I've only used the lights on 1 project so far, but I think that the lights made all the difference. I'm looking forward to breaking out the buckets a lot more in the months ahead.
Justin Walter is offline   Reply
